Thread: Silly plastic cracking sound when I go over bumps and turn corners !!
Page 1 of 3 123 LastLast
Results 1 to 10 of 26
  1. Silly plastic cracking sound when I go over bumps and turn corners !!
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    A few people have talked about this on the forum.. I have made comments on it myself, but this sound is doing my head in.
    Going over bumps .....and turning right or left up a hill
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
  2. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Oct 2012
    United Kingdom
    BUMP
    I have the exact problem. It is so frustrating, it sounds like it is coming from the back of the car.
  3. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Nov 2012
    Somerset UK
    I think best address by process of elimination, so get someone in the back (strapped in of course) and try and reproduce, then using a combination of something like rubber door stops (to move trim away) or masking tape (to hold trim away), apply one at a time to see if any improvement.
    I assume interior since spring/shock bump stops wouldn't be affected by turning, but bumps indicate up/down movement and corners indicate body flexing side to side.
    When I've experienced anything like this I've got my children to try and identify it/ hold their hands or press on trim panels (not thankfully on my A6 though, they can usually feel it through their fingers.. That said the previous owner had applied small foam blocks between both the windscreen and dash and rear parcel shelf (?) on my saloon, I am guessing due to squeaking.
  4. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Jun 2010
    10 Post(s)
    I am a big fella... I got the missus to drive around with me in the boot of the avant!!! I have pimped tinted 3/4 glass so no one could see me.... Then the missus decided to be a little carefree with the throttle!!! Fun times !!!!
    Previous:
  5. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    May 2012
    Ireland
    @poosnip what car have you got or did you mention already? I have the same cracking noise over bumps. Mine is an Allroad. I've tracked it down to the pullout cover that clips into the slots in the rear pillar. The noise seems to come from the movement of this cover.
    1 1 0
  6. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Jun 2010
    10 Post(s)
    I have an avant like you motion....When my someone is sat in the back behind the driver the creaking is much reduced,...
    Previous:
  7. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Jun 2010
    10 Post(s)
    2.7 tdi c6 avant
    Previous:
  8. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Jun 2010
    10 Post(s)
    Quote Originally Posted by motionpotion View Post
    I suspected this much.... Today I will take all of that stuff out and test
    Previous:
  9. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    May 2012
    Ireland
    Same setup as mine then. Is the bench part of your rear seat out of place? If somebody sitting on it and the noise stops it might be the cause. I took out my whole rear seat and made sure it was secured but the cracking persisted.
  10. Re: Silly plastic cracking sound when I go over bumps and turn corners !!
    Oct 2012
    United Kingdom
    I know the focus here is the plastic parts. But could it possibly be shocks/springs area. This noise concerns me from a cost aspect.
    Note: I have the A6 C6 2007
  1. cracking rattle
    By scaramac in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 02-06-2010, 11:35 PM
  2. sound silly but..........!
    By stevesellars in forum Golf MK3 - 1993 - 1999
    Last Post: 09-02-2010, 01:19 PM
  3. Passat 03 weird sound when I turn left
    By gun_em_down in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-02-2009, 05:54 PM
  4. Cracking paint.......
    By humek in forum Audi A3 - Archive Topics
    Last Post: 19-06-2008, 11:07 AM
  5. cracking sound when braking
    By arena432 in forum Chat - Completely Off Topic
    Last Post: 14-07-2005, 05:19 PM
