Thread: VAG-Com not reading- ???any ideas
  1. VAG-Com not reading- ???any ideas
    Sep 2007
    Edinburgh
    New V W owner in nightmare with 1998 Passat SE 1.9 TDi (90bhp)- done 99K- no history- amongst other things poor power, not revving above 2000rpm ?over/underboost, and independent garage (recommended on this forum) unable to read codes from diagnostics.
    They have never had this before, and we have no manual, so they are not sure which fuses to check- or any other reason why diagnostics not reading- there machine is working on other vehicles fine.
    Already spent £700 on Clutch and DMF replacement- to find this-aaargh!!!
    Any help gratefully received!!!!
    Thanks,
    Beefybov
  2. Re: VAG-Com not reading- ???any ideas
    Dec 2006
    Manchester
    Quote Originally Posted by beefybov View Post
    Thanks,
    Beefybov
    The only thing i can think of is to check the connections at the back of the interface on the car. If his lead works on other vehicles, then his equipment is fine.
    Good luck
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: VAG-Com not reading- ???any ideas
    131 Post(s)
    1974 Post(s)
    Will it read other controllers on the car, such as ABS, or nothing at all?
  4. Re: VAG-Com not reading- ???any ideas
    Sep 2007
    Edinburgh
    It's not reading any information at all. Thanks for your help.
    Beefybov.
  5. Re: VAG-Com not reading- ???any ideas
    131 Post(s)
    1974 Post(s)
    Check fuse 12.
  6. Re: VAG-Com not reading- ???any ideas
    Sep 2007
    Edinburgh
    You were right bora (ing) Nick.
    It turned out that an alarm system had been fitted, and subsequently, when removed, the wiring for the diagnostics had been disturbed and had been incorrectly replaced.
    Once wiring correctly sorted, diagnostics worked and reported air mass meter problem and cooling sensor needing to be replaced.
    I will let you know if these fairly cheap replacement parts solve problems.
    If so I will be very very happy.
    Thanks for all help.
    Beefybov
  7. Re: VAG-Com not reading- ???any ideas
    Dec 2006
    Manchester
    Beefybov
    Glad you got sorted....
    Make sure you get the AMM from VW or Audi. I've heard the replica's (even bosch units) are prone to being faultystraight out of the box.
    Don't think theres that much of a price difference anyway.
    Nick
    1.9 tdi PD 100 Bora
    By beefybov in forum Passat - B5 Forum - 1997 -2005
    Last Post: 27-09-2007, 04:57 PM
  2. fault reading question
    By madmonk in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 10-08-2007, 09:09 PM
  3. Mpg Clock Reading Erratic
    By hollow in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-03-2007, 01:40 AM
  4. Temp Gauge reading
    By Spaceman in forum Audi A3 - Archive Topics
    Last Post: 07-03-2007, 04:40 PM
  5. New to Reading Berks
    By The Boss in forum New Member Introductions
    Last Post: 04-03-2007, 11:04 PM
