Thread: Audi A4 2.5TDi fuel pump coding
Results 1 to 10 of 11
  1. Audi A4 2.5TDi fuel pump coding
    Dec 2006
    Hi ive got a 2002 52 Audi A4 2.5 TDi Avant. Car broke down and diagnosed with fuel pump fault. I went away and told family to order a recon fuel pump for it. This was done and fitted by a garage. I was told the recon pump would have a virgin ecu so wouldnt need coding. However by the look of things, it looks like the pump has come from another car. I have managed to extract pin from ecu on my car but is there any way of finding out the pin for the pump ecu that is now on the car?
    If not would Audi be able to do it for me?
    Thanks.
  2. Re: Audi A4 2.5TDi fuel pump coding
    Feb 2009
    Ireland
    Audi could do it but if you have the PIN extracted from the ECU you are half way there. The new ECU comes open for a new code so all you need to do is follow the procedure for coding the pump on the Ross Tech website. Second hand pumps are a different story as you need both the code from the donor vehicle and your own PIN as well in that case.
    Immobilizer III Injection Pump Swapping - Ross-Tech Wiki
    If you have the full version of VCDS you can do it yourself or expect to pay around £50 for AN Other to do it for you. The dealer will charge a fair bit more I would expect.
  3. Re: Audi A4 2.5TDi fuel pump coding
    Dec 2006
    I was told the pump was reconned but im pretty sure its a cleaned up second hand one so i dont have the pin for the old one. Will Audi be able to extract this. Cost isnt the end of the world now, just want it to go.
    Quote Originally Posted by abyrne153 View Post
  4. Re: Audi A4 2.5TDi fuel pump coding
    Feb 2009
    Ireland
    I don't think you can extract the PIN from the ECU on the pump though I am not 100 % sure of this. As far as I know you need the donor car complete with key and extract the PIN from the engine ECU from it. If your pump has a new ECU fitted , which is normal if it is reconditioned, then all you need to do is match it to the car using the Ross Tech procedure as it comes open and ready to receive a new code. You would need to establish for sure if there is a new ECU fitted from whoever supplied it if at all possible. There is a way of deleting the immobiliser although I have never done it. It means security is seriously compromised and although the car will start and run the immobiliser light flashes continually if my memory serves me right. If you could get in touch with Adamss24 on this forum he will be able to offer advice as he knows everything that is worth knowing about these engines.
  5. Re: Audi A4 2.5TDi fuel pump coding
    Dec 2006
    Thanks very much for the advice but it looks like its a second hand pump so could be really struggling.
  6. Re: Audi A4 2.5TDi fuel pump coding
    Feb 2009
    Ireland
    Try to get in touch with adamss24 before giving up. He really knows his stuff and if anything can be done he will know about it.
  7. Re: Audi A4 2.5TDi fuel pump coding
    Nov 2016
    Nelson South Wales
    I have been offered another Allroad with a similar issue. The guy has his self another good working pump but after fitting the car still wont run. how can we sort this or is it a waste of time and effort ? Thanks Paul.
  8. Re: Audi A4 2.5TDi fuel pump coding
    Sep 2008
    6 Post(s)
    Check out http://www.dieselbob.co.uk/index.aspx
    I've followed a number of these threads and Diesel Bob has a good reputation. It does say on his website that he needs original pump to overhaul, rebuild and test otherwise you're looking at a replacement pump.
    2016 BMW i3 REx (80k)
  9. Re: Audi A4 2.5TDi fuel pump coding
    Nov 2016
    Nelson South Wales
    Thank you for that information. The guy who is selling the car has another pump that he paid £100.00 in working order and then paid £80.00 to have the code wiped. He was told it would work with any ECU lol. It didn't and he then spent a load on trying to get it to run. He just sold the car for £575.00 £5.00 more than I offered he. Thanks Paul
  10. Re: Audi A4 2.5TDi fuel pump coding
    Dec 2006
    Quote Originally Posted by Bahamacharger View Post
    Immobiliser is in the fuel pump so if its later than around 2002- its a waste of time in my opinion.
  1. 2.5tdi Quattro In Tank Fuel Pump
    By aliw in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 16-03-2012, 08:20 PM
  2. Question Help with 2.5TDI fuel pump
    By Jameswoods in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 18-02-2010, 09:53 AM
  3. Question A4 2.5TDi V6 died is it fuel pump?
    By pagreen69 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-09-2008, 06:29 PM
  4. A6 2.5tdi 2002 fuel pump?
    By mujhool in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 04-08-2008, 09:18 AM
  5. 2.5TDi fuel pump failure
    By Cool384 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-05-2007, 05:48 PM
