Thread: Oil leak intercooler pipe?
  1. Oil leak intercooler pipe?
    Oct 2014
    haworth, yorkshire
    Hi there again, I`ve had the engine tray off my `53 A6 2.5 diesel and there in a slight but noticeable show of oil from the large, what looks like intercooler pipe on the off side off the engine as you look upwards. There is a sensor in the pipe which could be the culprit. Is either of these prone to leaking or in the case of the pipe spliting? I wiped the oil off the areas so as to get a better idea of where the leak is from but as yet no signs, Any ideas please?
  2. Re: Oil leak intercooler pipe?
    Mar 2013
    Virginia Co Cavan Ireland
    It's an intercooler pipe alright but it's not leaking as such, these engines all draw a bit of oil through the intake system and this is what you see weeping from these joints. Nothing to worry about really.
    Mick
    Mick
    99 Bora Tdi
  3. Re: Oil leak intercooler pipe?
    Oct 2014
    haworth, yorkshire
    cheers Mick, but does anything need retightening or do we just put up with it?
  4. Re: Oil leak intercooler pipe?
    Mar 2013
    Not really much you can do, I've heard of people cleaning out the intercooler with petrol and leaving it to dry for a day or two before refitting but it only stops it for a while, I've had superbs, boras,passats and on an a6 now and they have all done it but never bad enough to do anything about.
    Mick
    Mick
    99 Bora Tdi
  5. Re: Oil leak intercooler pipe?
    Oct 2014
    haworth, yorkshire
    ok cheers,
  1. oil leak from intercooler
    By churp in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-08-2012, 03:03 PM
  2. oil from intercooler pipe
    By technohippy in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 08-03-2010, 09:04 PM
  3. intercooler or pipe leak
    By mbu10 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-07-2008, 10:36 AM
  4. oil in intercooler pipe
    By nudger in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-03-2008, 09:14 PM
  5. Oil Leak from Intercooler pipe
    By Audi6er in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2007, 02:04 PM
