Thread: Seat Alhambra 2.0 tdi 6 speed gear lever moves but no forward or reverse motion with engine running
  1. Seat Alhambra 2.0 tdi 6 speed gear lever moves but no forward or reverse motion with engine running
    Nov 2010
    Cambs
    Hi.
    Happened quickly and with no warning. I was driving the car, changed gear, no engagement with engine. Pulled into the side, tried all gears with engine running. Nothing, although easy to move gear lever from one gear to another but no traction. 65000 on the clock and in good nick. Bought 3 months ago. Any help please.
    Thanks. Vgaf
  2. Re: Seat Alhambra 2.0 tdi 6 speed gear lever moves but no forward or reverse motion with engine running
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    hi
    any difference in how the clutch feels, any change in noise when you press the clutch in? Rattles, knocking? Driveshaft bolts still in place?
    Can you see the cables moving the selector on the top of the gearbox?, with an assistant obviously.
  3. Re: Seat Alhambra 2.0 tdi 6 speed gear lever moves but no forward or reverse motion with engine running
    Nov 2010
    Cambs
    Hi Rob and thank you for the response. No noises, clutch feels the same. Engine sounds fine. It's just not engaging in any gear although the gear lever is just as easy to move from one gear to another, as before. I have not had chance to look at cables etc as car was towed to a garage, in the dark....and it will be there until tomorrow.
  4. Re: Seat Alhambra 2.0 tdi 6 speed gear lever moves but no forward or reverse motion with engine running
    Nov 2010
    104 Post(s)
    Ok
    Sounds like they'll give you the verdict tomorrow then. Hopefully simple fix
    My old man had a drivehaft come loose after a clutch replacement, car wouldnt move same as yours, clutch guy had forgot to tighten bolts up an one of them was found still with his spline tool in it in the bottom tray!
  5. Re: Seat Alhambra 2.0 tdi 6 speed gear lever moves but no forward or reverse motion with engine running
    Nov 2010
    Cambs
    Just replied to say thanks Rob but it disappeared. So, Thank you.
    Your thoughts are valuable and led me to think that I wouldn't be able to move the lever into all gear positions if there was a clutch problem and it may well be the cable linkages or similar....ie not the clutch or the gearbox itself....he says hoping!
    Any other ideas welcome please.
    I will let you know if I hear from the garage.
    OK. Garage service manager said would have to take the gearbox out......something to do with the clutch and flywheel?
    Adding a rough quote of £1400! It seems excessive but I don't know about these things. The last Alhambra lasted 16 years without major mishap and was still going strong at 200200 miles when chopped in for this one.
  1. 1.9 TDI 6 gear Alhambra - intermittent engine judder
    By Andy_Seat in forum 1.9TDi - Engine
    Last Post: 04-09-2010, 12:33 PM
  2. Replies: 1
    Last Post: 17-02-2010, 03:07 PM
  3. Reverse gear hard to select on 2.5TDi 6 speed
    By dean warren in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-10-2009, 11:06 AM
  4. Please Help Replacing/Removing Golf Mk5 Handbrake Lever Cover & DSG Gear Lever/Surround ?
    By shaft-50 in forum Golf MK5 - 2004 - 2009
    Last Post: 16-05-2009, 04:50 PM
  5. SEAT ALHAMBRA Se TDI engine spluttering
    By twindecks in forum Alhambra
    Last Post: 14-08-2008, 09:00 AM
