Thread: A6 C6 rear suspension dropping
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: A6 C6 rear suspension dropping
    Ayrshire, Scotland
    18 Post(s)
    Quote Originally Posted by PaulF2.5TDi View Post
    Thanks Crasher,
    I suspect the valve block - but am trying to eliminate the cheaper options first!
    I still haven't tried light oil through the pneumatic side of the solenoids yet.
    I also wonder how the water is drained out after multiple compressor operations?
    For info, the rear air spring is around £300 from Audi (not exact as I asked them for a price around the time when I started the thread) - not awful!
    ( I hadn't asked for a valve block price..……)
    Out of interest, why would it not deflating in Jack mode indicate a valve block, and if intermittent why could it be an air spring?
    Hi Paul,
    On the C5 its usually the airbag which causes the strange intermittent sinking as the airbags on the C5 only tend to leak when the car is at its lowest suspension setting. I would be suspecting the airbag at fault from your description. to check this park your car overnight at its lowest level and monitor it, then park it at its highest level, if it always sinks at one and not the other it is the airbag,
    the valve block is not so likely, as you would need multiple valves to be stuck open. the valve bock has 6 valves, 1 for each of the 4 corners, 1 for the compressor and 1 for the storage tank, so if your rear left valve was stuck open the car would still not sink as at least one other valve would need to be opened and even then only the compressor valve would cause the car to lower. so to have the rear left and compressor valve opened is less likely. even if the valve body was cracked then it would sink all the time at any level.
    that's a cheap price for the airbag?
    the valve block is about £150
    the system lets moisture out by venting every time the compressor stops, you hear a sharp Whoosh when the compressor stops this is the N111 valve venting pressure and moisture out the airline to the valve block.
    the reason on the C5 for sinking only at low setting is the airbag rubber perishes at the lower fold on the airbag, and perished rubber when you fold it the cracks open and so air leaks, but lft the car to a higher setting the cracks physically move 25-50mm higher to the straighter part of the rubber and so the cracks close,
    if it never sinks at low or high while in jack mode then its an electrical issue, could be valve block 10 pin connector of level sensor but I would hope to see a fault code for those,
    do the parking at low and then high test over the next few nights, and let us know what you find
    best regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  2. Re: A6 C6 rear suspension dropping
    131 Post(s)
    1978 Post(s)
    The valve block is £290.99, the system drains from the pump body mounted suspension controller electronically operated drain valve, for which there is a £75.60 repair kit.
  3. Re: A6 C6 rear suspension dropping
    Aug 2012
    Aberdeenshire
    Thanks guys,
    It's in 'Jack' mode at the moment, on 'Lift' setting and has been up for a couple of days now.
    I'll put it in 'Dynamic' this afternoon and lock it in 'Jack' mode and see where it goes.
    The problem with this sort of fault is it takes an age to confirm the exact sequence of events, but with the cost of the parts I'm not just swapping bits without confirmation!
    The C6 spring is separate to the damper - unlike the C5 and it looks like you can only buy the complete spring and not the bag.
    As a result, leak checking it appears all but impossible.
    (I haven't taken the bellows off yet to confirm)
    AUDI A6 ALLROAD QUATTRO [A6AR] (EUROPE) 2007: REAR AXLE: 51110. AIR SPRING; SHOCK ABSORBERS; ANTI-ROLL BAR
    From the above, looks like the spring repair kit is just for the bellows.
    Interesting there is a repair kit for the drain valve - also the differing mod states.
    2000 A4 B5 2.5 TDi Quattro Avant, Maroon SOLD
    2000 A4 B5 2.5 TDi Quattro Saloon, Blue SOLD
    2006 A6 Allroad 3.0 TDi, Blue - getting ready to get rid of
    2008 A5 3.0 Tdi Quattro Coupe, Grey
    2010 A6 Allroad 3.0 TDi, Blue
  4. Re: A6 C6 rear suspension dropping
    131 Post(s)
    1978 Post(s)
    Yes, you need part number 4F0 616 001 J which is £333.62 inc.
  5. Re: A6 C6 rear suspension dropping
    Nov 2012
    coalville leicestershire
    Hi I am also getting an intermittent drop on the right rear.
    I will try leaving it in High & Low setting to see if there is any difference
    Seems odd that 3 people have the right rear drop, no fronts or left rears?
    PaulF2.5TDi, have you made any progress in finding the fault?
    0 2 0
  6. Re: A6 C6 rear suspension dropping
    Aug 2012
    Aberdeenshire
    I keep meaning to write a piece with photos, but yes I replaced the spring following Andy's and Crashers input and all is now fine.
    I got the spring from here - Audi A6 - C6 Allroad Suspension Air Spring Rear - Left or Right - Air Bag 04-11 | eBay
    It was not too difficult to do-
    Put the car in lift, and then engage jacking mode on on the MMC
    Jack the car by the chassis until the wheel is off the ground, rest on an axle stand or similar and remove the rear wheel.
    Undo the two screws either side of the shock strut and pull the wheel arch liner out of the way.
    Cut the tie wraps holding the spring air pipes to the body, and undo the pipe at the connector the air will hiss out
    Undo the bolt under the arm holding the spring in place (it is a spline bolt, NOT torx or Allen - can't remember the size)
    If you are replacing the spring, use a pin punch or similar bit of metal/bolt and loosen the spring in its seat with a big hammer.
    I then screwed a wheel bolt into the hub and put a deep socket over it with a load of 1/2" extension bars.
    I sat on the bars, pulling the hub down and removed the spring with a bit of jiggleage
    Cleaned up the 'seat' and transferred the pipe
    Sat on the spring to compress it and then sat on the extension bars and stuffed the spring into its seat - lining up the notch (really obvious and easy to do)
    Replaced bolt in the bottom of the spring and got off the 1/2 extension bars then removed the wheel bolt from the hub
    I then used a compressor and bed inflator (blue IIRC) to inflate the spring a bit
    Then connect the air hose and ty-wrap it as it was previously
    Refit the wheel arch cover and wheel then drop the car onto its wheels
    Start the engine, release the jack mode and select dynamic.
    There may be error lights flashing- depending how much you inflated the spring
    Once all is in dynamic, turn off, then restart and select another mode
    The lights went out and it rose much faster than it used to.
    All is now good.
    Less than two hours with stopping for beer
    I decided did not need VCDS for this as the spring is dumb - it just inflates until the sensor says stop and Elsawin made no mention of it.
    About two months later I has a suspension light (I can't remember the code but it was to with calibration) that I decided needed a calibration post spring change so did - there were differences that may, or may not have been there before.
    I also found a wheel with low tyre pressure and inflated it……….. you decide what fixed the problem so whether you need VCDS for the change but I suspect the tyre inflation was the problem!
    2 3 0
  7. Re: A6 C6 rear suspension dropping
    #17
    Ayrshire, Scotland
    18 Post(s)
    sounds like another airbag, rear airbags go 1st on the C6 for some reason, on the C5 its the fronts
    best regards
    Andy
    2 1 0
  8. Re: A6 C6 rear suspension dropping
    #18
    Aug 2012
    Aberdeenshire
    You and Crasher were spot on with my one Andy cheers for the help.
  9. Re: A6 C6 rear suspension dropping
    #19
    Nov 2012
    Thanks guys
    I'll get the parts ordered & swap the airbags out
    Recommend to replace both at the same time or wait for the left hand side to fail before changing?
  10. Re: A6 C6 rear suspension dropping
    #20
    Aug 2012
    Aberdeenshire
    I just did the one - FWIW
  1. Rear suspension on GT
    By Dmo238 in forum Golf MK7 - 2013 - 2019
    Last Post: 11-05-2013, 02:40 PM
  2. Allroad suspension dropping at one side plus acoustic parking not working
    By garyizme in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-02-2013, 10:34 PM
  3. Allroad suspension dropping
    By garryjeffrey in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 01-11-2010, 10:07 PM
  4. Dropping subframe to remove lower rear control arm bolt
    By trevMk2 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-06-2010, 09:46 AM
  5. Question Sourcing parts for failed MOT - rear shock/rear discs/front suspension ball joint
    By richienat in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 08-07-2009, 10:26 AM
