Thread: Polo 1.0 (6N) 16684 & 16688 Misfire Codes
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: Polo 1.0 (6N) 16684 & 16688 Misfire Codes
    Sep 2009
    South Wales
    I would say so, that means the insulation has broken down, and the easiest path for conductance is anywhere but where it's supposed to be. You might not always see this, is the problem worse when cold/damp? or warm?
    Keep in mind that sometimes the sparks arent always easily visible, so its not a surefire - an indicator.
    If when the car heats up its harder to start with the engine warm, or requires a few minutes before it will start then that sounds like the coil needing to cool down in order to operate "correctly".
    I had one coil fail so spectacularly you could hear it arcing (and crackling an awful lot) out behind the dash when you were driving or starting the car sometimes. That got changed quick snap!
    Current: Golf VI 1.4 TSI
    Past: (Beloved) Mk3 "1.6" - 184 k miles. Now a cube in scrapyard heaven :'(
    I need all your V-Powers.
  2. Re: Polo 1.0 (6N) 16684 & 16688 Misfire Codes
    Kettering, Northants
    After recharging battery (see other thread...!) got it started this evening and a nice little intermittent spark display going on low down behind the coil pack. Hopefully job done but I'll report back to confirm after fitting a new pack at the weekend.
    Thanks to all for their help so far.
    There are 3 kinds of people in the world, those that can count and those that can't.
    1 1 0
  3. Re: Polo 1.0 (6N) 16684 & 16688 Misfire Codes
    Coil pack replaced, all now running well with no engine fault codes!
    Again, thanks to all.
  1. Question engine misfire but no fault codes
    By waynelivesey in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 29-04-2011, 03:16 PM
  2. 99 A6 Avant 4.2 - misfire but no fault codes
    By sparkyjf in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 08-08-2010, 08:20 PM
  3. Please Help 1.8t misfire no fault codes
    By aggiss in forum Golf MK4 - 1999 - 2004
    Last Post: 09-10-2008, 10:40 AM
  4. Golf 4 misfire with no fault codes
    By kalahari in forum Golf MK4 - 1999 - 2004
    Last Post: 04-03-2008, 08:44 PM
  5. VAG-COM Engine Fault 16684 - Misfire
    By richjthorpe in forum Audi A4 - Archive Topics
    Last Post: 30-01-2007, 09:56 AM
