Thread: Blue smoke from the exhaust.
  1. Blue smoke from the exhaust.
    May 2007
    Edinburgh, Scotland
    Well, just noticed the other day when I was stuck in traffic. The car heated up a bit more than usual (fan came on). I then drove away from a junction leaving a cloud of light blue smoke. I know this from common sense to be oil, but is it the valve stem seals or the piston rings? I have been given the impression that piston rings give smoke on acceleration, while the valve stem seals give smoke on the overrun. It only happens when the engine gets to normal operating temp or above and I blip the throttle. If I move off very gently it gives off hardly any smoke.
    1991 Golf 2 Driver.
    1.6 EZ
    "THE BEAST" also known as "THE SHED"
  2. Re: Blue smoke from the exhaust.
    Aug 2007
    most likely to be the valve stem oil seals, the reason it only does it when warm is that oil is too viscous to pass them when cold. you can check the condition of the rings by performing a compression test.
  3. Re: Blue smoke from the exhaust.
    Canada
    Valve stem seal are the most common problems.
  4. Re: Blue smoke from the exhaust.
    May 2007
    Edinburgh, Scotland
    Cheers guys, i'm replacing the timing belt and rocker cover gasket so might grab some seals and do them while I'm at it. Mr Haynes says you can do it without taking the head off so I might have a bash.
    1991 Golf 2 Driver.
    1.6 EZ
  1. VW 2.5 tdi Transporter blowing blue exhaust smoke
    By lyndail in forum The Commercial Range
    Last Post: 20-06-2007, 01:36 PM
  2. Blue smoke -- Help!
    By mrsheen in forum The Commercial Range
    Last Post: 09-06-2007, 08:14 AM
  3. Blue Smoke in the morning
    By Rhino in forum Passat - Archive Topics
    Last Post: 28-03-2007, 11:25 AM
  4. Dreaded Blue Smoke ....
    By Jabba in forum Passat - Archive Topics
    Last Post: 02-03-2007, 06:34 PM
  5. Blue smoke in traffic
    By avhation in forum Archive posts
    Last Post: 21-11-2006, 12:21 PM
