Thread: Boot Rattle
Results 1 to 10 of 12
  1. Boot Rattle
    Aug 2013
    Embra
    Anyone have a quick fix to the boot rattle ?
    It's kind of a loud click or bang when going over a larger bump - like a snare drum.
    I think it comes from the parcel shelf mounting or maybe the boot floor cover.
    I'm about to plaster the lot in soft rubber inserts but pointers would be welcome first.
  2. Re: Boot Rattle
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Exhaust heat shield come adrift maybe ?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Boot Rattle
    Jun 2010
    Manchester, United Kingdom, United Kingdom
    10 Post(s)
    Mine does it .... Sounds like a plastic rattle. For me it occurs when I go over a bump, but it's more pronounced when the rear suspension is under load...say when i turn on an incline. I don't think it's a trim rattle .... Someone on here has said that it was the bump stops on rear suspension
    Audi A6 C7 Allroad 3.0 TFSI.
    Previous:
    Audi A6 C6 2.7TDI Le Mans.
  4. Re: Boot Rattle
    Aug 2013
    Embra
    I'm sure it is inside, maybe the boot floor cover ?
  5. Re: Boot Rattle
    Jul 2013
    76 Post(s)
    Check the lock striker, it may have come loose.
    a quick way to find out is to wrap tape on it.
    Dan
    2009/2010 2.0 TDIe SE
  6. Re: Boot Rattle
    Aug 2013
    Embra
    Tape fitted.
    I've also put rubber padding undetr the boot floor cover at the edges.
    Will report back.
  7. Re: Boot Rattle
    Jul 2007
    Chorley
    I had this noise. I will spare you the details of how the indy I use couldn't be ***** to find it and how I was ripped off by the main dealer who failed to solve it.
    I took the rear wheels off and removed the wheel arch liner N/S. Poked around in there and pulled at the brake line that is visible. As I pulled at the pipe it made the noise!
    I got under the car and pulled on the brake line and saw it was hitting the heat shield.
    I unbolted one corner of the heat shield and reformed it to give more room for the brake pipe, refitted the heat shield.
    Road tested the car car and the noise was gone.
    A6 2007 2.0 TDI Saloon
    A4 2002 1.9 TDI Avant
    2 1 0
  8. Re: Boot Rattle
    Aug 2013
    Embra
    @santiago - Sounds like you have had the same issues I've had with garages
    Do you have pics of what you found so I can check ?
  9. Re: Boot Rattle
    Jul 2007
    Chorley
    I'm sorry I didn't take pics (note to self, take picture when fixing things)
    With the NS rear wheel off with the lining still in place you should see the a 3" section of brake pipe (centre bottom of the liner).
    If it will help you I will take the wheel off tomorrow and take some pictures for you.
  10. Re: Boot Rattle
    Aug 2013
    Embra
    I'm away for a couple of days tomorrow so I'll check that when I get back on Saturday if the rattle is still there.
    Happy new year!
  1. Question A3 2004 Boot / Boot button on Key fob
    By youngybear in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 23-02-2010, 09:52 AM
  2. No boot light,could i be loooking at a new boot lock???
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 12-01-2009, 11:53 AM
  3. Please Help Speaker Rattle from boot
    By Gurraj_Singh in forum In Car Entertainment
    Last Post: 06-01-2009, 10:19 PM
  4. Boot sill guard & boot spoiler?
    By james_tiger_woo in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 23-07-2008, 06:10 PM
  5. boot warning sensor comes on the display when the boot is shut
    By merchantmr in forum Audi A4 - Archive Topics
    Last Post: 06-02-2007, 10:04 PM
