Thread: Digital clock dispaly and mileage recorder unreadable / broken llines
  1. Digital clock dispaly and mileage recorder unreadable / broken llines
    Dec 2014
    London
    hi
    I have a 2004 Cabriolet 1.8 T and the digital clock display and the mileage recorder display is a mixture of broken lines
    Can any one advice on how to fix - checked the fuses but don't have an owners manual as the vehicle was brought 2nd hand so might have missed the right fuse
    It also developed another fault the hand brake sign comes on and it pings at me when I went around the roundabouts but the hand brake was definatly off but now it has warmed up it has stopped - it was only about 2 degrees outside when this happened
    any help would be gratefully received
  2. Re: Digital clock dispaly and mileage recorder unreadable / broken llines
    46 Post(s)
    Common problem, you need a new DIS screen. Google BBA Reman for a fix.
    Not sure on the handbrake, maybe a switch. Get it scanned with VCDS or a fault reader.
  3. Re: Digital clock dispaly and mileage recorder unreadable / broken llines
    Dec 2014
    London
    the Central panel is fine - it is the two displays either side of the Central panel that isn't displaying properly / the ones under the dials
    doing from memory but the clock / date and then the left hand side total mileage the car has done
    does the above do all three displays
  4. Re: Digital clock dispaly and mileage recorder unreadable / broken llines
    Sep 2008
    chester
    17 Post(s)
    Temp will not affect the handbrake warning check the micro switch on the handle,if its coming on with low temp could be an electrical gremlin with the outside air temp alarm on the lcd panel,you could try re-soldering the contacts on the panel.
  1. Question How do I change the digital clock in my T5 to 12hr time format?
    By Lemmiwinks in forum The Commercial Range
    Last Post: 22-11-2009, 09:24 AM
  2. getting digital mileage readout
    By seanplater in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 09-09-2008, 08:03 PM
  3. Mileage recorder in km - how can I change back to miles
    By Paddywhack in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-04-2008, 11:08 AM
  4. Digital milometer and clock not working!
    By tows971 in forum Golf MK4 - 1999 - 2004
    Last Post: 05-02-2008, 12:38 PM
  5. A3 digital mileage recorder now reads in kms, how do I change it back?!
    By dogcats123 in forum Audi A3 - Archive Topics
    Last Post: 24-09-2007, 04:36 PM
