Thread: Disconnecting my Battery
Results 1 to 10 of 11
  1. Disconnecting my Battery
    Jan 2011
    Stafford, UK
    I need to disconnect my battery.
    Will I lose anything and will I need to recode anything when I reconnect the battery?
    Thanks.
    2009 - A6 2.7 TDI (CANA) - S Line - Avant (Multitronic) Daytona Grey.
    Ross-Tech - http://www.ross-tech.com/vcds/tour/main_screen.html
    Screen capture - FastStone Screen Capture - The Best Screen Capture Software
  2. Re: Disconnecting my Battery
    Nov 2009
    46 Post(s)
    One touch for the windows, time and date.
    2 1 0
  3. Re: Disconnecting my Battery
    Jan 2011
    Stafford, UK
    Quote Originally Posted by Chris View Post
    One touch of what for windows Chris?
    Is it really that simple?
    I thought that I would lose all of my vcds setting like needle sweep etc.
  4. Re: Disconnecting my Battery
    Nov 2009
    46 Post(s)
    Yes the one touch for the windows, time and date is all you'll lose. Nothing else.
    2 0 0
  5. Re: Disconnecting my Battery
    Jun 2006
    You may loose the trip mileage.
  6. Re: Disconnecting my Battery
    Jan 2011
    Stafford, UK
    Quote Originally Posted by apole View Post
    That's no problem as I don't use it, but thanks.
  7. Re: Disconnecting my Battery
    Apr 2013
    Stirling
    11 Post(s)
    Hi Roy, your traction control light may come on as well... But after driving the car a few meters it'll come back off! Might be a good idea to clear out the fault codes when all is connected back up 👍
  8. Re: Disconnecting my Battery
    Jan 2011
    Stafford, UK
    Thank you all.
    Disconnecting the battery is going to be less of a trauma than I at first imagined.
  9. Re: Disconnecting my Battery
    May 2012
    Ireland
    @Chris, I'm also going to disconnect battery to replace it tomorrow. So for clarity, what does "One touch for the windows, time and date." mean?
    Does it mean they have to be reset with VCDS or can they be reset from the MMI after the battery is connected back up?
  10. Re: Disconnecting my Battery
    Nov 2009
    46 Post(s)
    Comfort function for the windows. Just press and hold each window switch on your drivers door for 5-10 seconds and the car will relearn the bottom and top of the window.
    3 2 0
  1. Disconnecting battery
    By Jonno40 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 28-08-2014, 10:48 AM
  2. Disconnecting Battery and Warning Lights
    By takksi in forum Golf MK6 - 2009 - 2013
    Last Post: 22-02-2013, 08:11 PM
  3. What things should I be aware of before disconnecting the battery?
    By mrdannyaitch in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 09-08-2012, 06:43 PM
  4. Disconnecting battery on my RS6
    By smonson in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 26-02-2009, 01:48 PM
  5. Disconnecting battery
    By SW TDi in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 22-01-2009, 11:23 PM
