Thread: Mk4 Golf 1.6 16v Throttle Body Cleaning
Results 1 to 10 of 10
  1. Lightbulb Mk4 Golf 1.6 16v Throttle Body Cleaning
    Dec 2014
    Eastbourne
    Hello, I've just recently joined as I bought a Mk4 Golf last weekend and I am new to the forum.
    Been doing a little research on a problem I had which was the EMISSIONS WORKSHOP indicator on the dash. Many threads I read mentioned cleaning the throttle body and realigning it.
    I am new to the diagnostic software but have downloaded VCDS-Lite and bought a cheap ebay cable. Cleared the fault code that was causing the EMISSIONS WORKSHOP light but obviously didn't cure the problem so I am just waiting for it to come back on.
    Back to the throttle body. My question is: what is the safest method to clean it?
    Can you clean it while it is attached (which I have done on previous vehicles) or should I remove it? Can I use carburetor cleaner instead of throttle cleaner (as I already have carb cleaner available). And can I spray into the intake with either the engine running or not and someone feathering the throttle?
    Also, I haven't tried it yet but can you realign the throttle body with VCDS-Lite (free version)?
    Many thanks
    James
  2. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Nov 2010
    Shetland & S.Tyneside
    104 Post(s)
    James
    You didnt mention what code it had logged, but check its not egr related before going into throttle body cleaning.
  3. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Dec 2014
    Eastbourne
    Quote Originally Posted by Rob69 View Post
    James
    Good point here is a snap shot of the VCDS code
    I also had the car stall a couple of times whilst slowing down for roundabouts or junctions and also whilst accelerating away on a dual carriageway, lost power and the engine cut out.
    James
  4. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Nov 2010
    104 Post(s)
    james
    check for vacuum leaks as engine is running lean. Also check maf sensor, you should be able to do this with vcds lite. More info on this forum or online. Sorry got to go, at work today so need to look busy.
  5. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Dec 2014
    Eastbourne
    Will check for vacuum leaks, thanks for the suggestion.
    Still looking for any recommendations on cleaning the throttle body, "Can you clean it while it is attached (which I have done on previous vehicles) or should I remove it? Can I use carburetor cleaner instead of throttle cleaner (as I already have carb cleaner available). And can I spray into the intake with either the engine running or not and someone feathering the throttle?"
    James
  6. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Apr 2012
    uk
    if your cleaning it while its attached please please do not have the engine started...the chemicals will ignite etc etc....big no no
    carb cleaner has a little lube in it if i remember correctly any cleaner will do really, best to take it off but im not sure if there is a gasket or if it will come off in one piece...spray a clean rag and reach in and clean it out would be my suggestion. If you spray directly into the throttle body and clean it...jam the throttle open and let it air out before closing it and starting the car
  7. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Dec 2014
    Eastbourne
    Thanks zmotor. My only concern is manually moving the butterfly valve. Because I'm not used to this electric set-up (previously owned older cars) can you move it with, say you finger, without damaging anything? It's not a drive by cable set-up, on previous cars I've owned I've just turned the part that holds the cable to the throttle to clean inside.
    I would prefer to take it off and clean it properly. Gaskets are relatively cheap anyway. The engine doesn't haunt, but does travel between 25-50rpm occasionally, mostly when I'm holding the rev's at 12,00-1,500.
  8. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Nov 2010
    104 Post(s)
    you cant realign throttle body with shareware vcds. Do all the basic checks before the throttle body. Check out other posts here for more info.
  9. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Aug 2011
    Meath
    Don't attempt to move the butterfly valve it's connected to little plastic gears. The throttle body is best removed for cleaning the underside. Is it very dirty? You'll need access to the full version of VCDS or similar to align the throttle
  10. Re: Mk4 Golf 1.6 16v Throttle Body Cleaning
    Dec 2014
    Eastbourne
    Thanks for all your replies, guys. Answered all the questions I had. Will let you know how I get on in the New Year.
    James
  1. Mk4 1.4 16v throttle body alignment problem
    By robbarlow in forum Golf MK4 - 1999 - 2004
    Last Post: 13-12-2016, 11:52 AM
  2. Please Help Throttle body cleaning?
    By rinupanu in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 01-02-2011, 08:14 PM
  3. Cleaning Throttle Body - 1.4 16v 2000 6n2
    By boilerchicken in forum Polo - Derby - Lupo - Fox
    Last Post: 21-01-2009, 11:40 PM
  4. Golf MK4 Throttle body allignement.
    By stupotads in forum VCDS - General Questions
    Last Post: 17-10-2008, 11:39 AM
  5. Golf Mk4 1.6 SR Throttle Body Cleaning
    By randall977 in forum Golf MK4 - 1999 - 2004
    Last Post: 30-04-2007, 09:48 PM
