Thread: 1.9 tdi really sluggish
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 44
  1. 1.9 tdi really sluggish
    Apr 2012
    uk
    Hi, this car is really starting to test my patience......a bit of background
    Audi A4 1.9 PD130 AWX currently at 156k miles
    Oil and oil filter service every 5k, ran on shell V-power diesel for the last 20k
    Ran great till a couple of weeks ago, after a nice 150mile trip i parked up let it cool then switched off, when i went to work the next morning it was a totally different car....very lazy and sluggish below 2.5k and very hard to get up to speed without really working the car. If i plant my foot in pretty much any gear it took an age before boost, between 1-2.5k it`s as if the turbo is asleep
    Only code i got was for a fuel temp sensor which presented when i changed the tandem pump seal + coolant pipe (yes it was plugged back in and no the ignition wasn’t on when it was unplugged..logs showed it stuck at 40.5 which changed when it was replaced)..strangely enough the code only appeared 3-4 weeks after the problem and pretty much straight after the tandem pump seal replacement. I also checked the fuel filter and there is no oil present to suggest possible injector seals, oil stays at the correct level suggesting no fuel/oil mixing via tandem pump. The car starts on the button every day, no smoke...just very sluggish below 2k in low gears going up hill if i plant my foot nothing happens till +2k...on the motor way its generally ok as its above 2k but does require more throttle to keep up to speed compared to before
    I didn’t log the fuel temperature when the problem occurred, the recent cold bite may have killed it but even after replacement it has made very little difference...
    Cars had the following done:
    Fuel filter (changed yearly)
    Timing belt (two years ago)
    Coolant + CTS + thermostat + viscous coupling (changed two years ago)
    Fuel temp sensor (recently)
    N75 valve (changed a year ago)
    Map sensor (changed a year ago)
    Injector harness (recently), cam is fine...injectors have never been touched
    MAF sensor (changed a year ago)
    Actuator checked, holds vac
    Turbo vanes are free and clean, turbo blades are nice too minimal play
    CAT isn’t blocked, neither is the EGR or intake
    Vac lines are all good so are all boost pipes, clamps + intercooler + in line check valve is good and the right way round..vac reservoir is solid..intercooler sound resonator is tight too.
    Tandem pump seal replaced (pump is still weeping from the back plate, so a new pump is on its way)
    Checked for broken wires/damaged harness....nothing
    All bosch/pieburg/genuine parts used
    As far as i can tell, everything is where it should be in regards to turbo/airflow..suggesting a fueling problem as the car is still sluggish... the tandem pump has been leaking for a while as the coolant line below it was very swollen and soft hence my motive to change the seal...as i said the back plate is still leaking so i will be replacing the pump...is this my problem? the leaking back plate drawing in air? i am unsure as its been leaking for a while but the car has always ran well...leading me believe this may not be the problem. I also thought the accelerator pedal but the car revs up fine at idle
    I have attached a log file...any help/advice is greatly appreciated.
    Dropbox - LbigOG-01-019-022-036-071-116-13F.csv
    Asad
  2. Re: 1.9 tdi really sluggish
    Pembrokeshire
    22 Post(s)
    the maf sensor you replaced, what did you use, was it a genuine one from a dealer ?
  3. Re: 1.9 tdi really sluggish
    Apr 2012
    uk
    its a bosch one from eurocarparts, its been on there for a year or so without problem (car ran great), i did swap it with a brand new replacement item from eurocarpart with no change so i put my old one back on and thought to look else where....
  4. Re: 1.9 tdi really sluggish
    Aug 2011
    Meath
    Have you had a diagnostic scan done?
  5. Re: 1.9 tdi really sluggish
    Apr 2012
    uk
    yes i own a vcds cable , nothings come up since the problem started only the fuel temp short to ground when i replaced the tandem pump seal, a log of which showed it was stuck on 40.5 continually...it was plugged in when i reassembled, i cleared the code and it returned so was definitely faulty just took its time to show up. I thought this was my problem, however since replacing it very little has changed
  6. Re: 1.9 tdi really sluggish
    Jan 2009
    Birmingham
    36 Post(s)
    Don't the tandem pump also do the vaccume for the car? you might need to change the pump or look around the pump for any split pipes vaccume side
  7. Re: 1.9 tdi really sluggish
    Apr 2012
    uk
    yes they do, inner part is for vac outer is fuel, all lines check out ok ive also epoxied the main vac line port as it was loose....replacement pump is on its way
  8. Re: 1.9 tdi really sluggish
    Sep 2008
    chester
    17 Post(s)
    Have you got a vac gauge,"T" it in to the line to the turbo.
  9. Re: 1.9 tdi really sluggish
    Apr 2012
    uk
    Ill get it done and report back when i return home next weekend
    what readings should i see?
  10. Re: 1.9 tdi really sluggish
    Apr 2012
    uk
    any more suggestions? will be checking the vac this weekend
  1. 2.0 Tdi 140 sluggish
    By ejs1995 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 11-02-2014, 10:26 PM
  2. 130 tdi b5 a4 sluggish
    By craigib76 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 14-07-2010, 10:16 PM
  3. V6 tdi Sluggish
    By pearcey555 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 24-02-2009, 12:18 PM
  4. Question sluggish 2.o tdi sline
    By saif786 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-10-2008, 02:16 PM
  5. Please Help TDi sluggish after repairs
    By markiparki in forum Golf MK5 - 2004 - 2009
    Last Post: 17-09-2008, 10:20 PM
