Thread: Should I also clear DTC does and...
  1. Should I also clear DTC does and...
    London
    Does anyone speak Fault-codish please ?
    I recently bought a Fault Code Reader, a Autel Vagsanner, to try and identify any possible reason for the severve but intermittent hesitantcy / jerkiness upon hard acceleration. I replaced the MAF and the Lambda sensor last week. Apologies if I am in the wrong forum - please advise.
    The Engine fault codes are:
    17833
    Tank Ventilation Valve, Short to Ground or EVAP Purge Valve (N80): Short to Ground: P1425
    17523
    Oxygen (Lambda) Sensor Heating Cuircuit: B1 S1: Short to Ground: P1115
    16486
    Mass or Volume Air Flow Circuit - Low Input or Mass Air Flow Sensor (G70): Signal too Low: P0102
    17697 Boost Pressure Control Valve (N249): Short To Ground: P1289
    17955 Boost Pressure Regulation Valve (N75): Short to Ground: P1547
    May I ask:
    (1)
    Should I Erase the codes then run the Fault Code Reader again (so that only those problems not already rectified will show up?)
    (2)
    Does the frequency with which the words "Short to Ground" appear indicate any common problem ?
    (3)
    Any suggestions on how I should proceed ? Any steer would be much appreciated.
    Thank you
    Kevin
  2. Re: Should I also clear DTC does and...
    London
    Help will anyone talk to me ? Am I in the wrong place ?
  3. Re: Should I also clear DTC does and...
    May 2007
    knee deep in clunge
    14 Post(s)
    Iam waiting for the other bloke to respond.
  4. Re: Should I also clear DTC does and...
    Canada
    I would clear the codes and see what re-appears. thats allot of short to grounds, either its a wiring fault or a sequence triggered by one event.
  5. Shorts to Ground - stange mix of DTC codes ?
    London
    Onzarob (or anyone),
    Thank you. I cleared all codes, they disaperaed then after a short drive, all 5 came back again. I cleared them again and they came back again.
    Interestingly, I have what I thought was an unrelated problem - when driving with the radio on in a weak signal recetion area, the radio seemed to stop/stutter for perhaps half a sceond every 10-20 minutes or so.
    I guss this means a trip to a specialist Auto Electrician (I am not impressed with my local VW deaer who msised these faults) but I woud like to keep trying a bit more. Do you reckon there is any single problem that might cause these shorts (e.g. water in a footwell, common wiring loom problem).
    Thank you
    Kevin Headache (well it's giving me one - that is why I chose this handle!)
  1. Should I clear DTC's?
    By xenon in forum VCDS - General Questions
    Last Post: 20-04-2009, 02:12 AM
  2. Clear indicator lenses for Cab
    By bestcara1 in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 21-03-2009, 10:25 PM
  3. Clear engine access
    By wblatchley in forum The Commercial Range
    Last Post: 29-07-2007, 09:47 PM
  4. Vag-Com : clear fault codes
    By keland in forum VCDS - General Questions
    Last Post: 11-05-2007, 09:43 PM
  5. Clear Indicators
    By Coupe16v in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 06-05-2007, 12:24 AM
