Thread: Alternator and power steering issues after serpentine belt change help
Results 1 to 9 of 9
  1. Alternator and power steering issues after serpentine belt change help
    Jan 2006
    Near Basingstoke
    futher to a previous post it look like my alternator is shot. The pulley is OK and spinning the alternator but there is no output. The alternator sounds very noisy so I am assuming that the bearings are knackered and therefore the brushes are worn out or not making contact. Also noticed squealing from the steering on hard lock, which I traced to steering fluid low (so assume a leak somewhere as isn't it a sealed system...or is that just a normal top up issue?). My question is that all of this was working Ok before the cambelt and aux belts were changed 2K miles ago. Is it possible that the new serpentine belt could be tighter and has damaged the bearings on the alternator and pump, could it be the wrong belt, could the tensioner be out of alignment. It all looks OK, the belt is tight and visibly spins OK. It may all just be co-incidence as the car has done 130K miles now, but before I start replacing alternators etc I want to be sure that a replacent is not going the same way!!
  2. Re: Alternator and power steering issues after serpentine belt change help
    Aug 2011
    Meath
    First check if the alternator clutch has gone
  3. Re: Alternator and power steering issues after serpentine belt change help
    Jan 2006
    Near Basingstoke
    clutch is turning the alternator in both directions, so isn't siezed but is also not slipping, so I am assuming that as it is knackered, but as it is spinning the alterrnator I am guessing that is also at fault. As it's about for a fully reconditioned OEM alt I am just gonna change the lot as by time I have bought the pulley and tool that is about 1/2 that cost. HAve taken alternator off. Is there some trick other than brute force and ignorance (which I can supply in spades) to get it out past the hoses?????
  4. Re: Alternator and power steering issues after serpentine belt change help
    Aug 2011
    Meath
    What engine?
  5. Re: Alternator and power steering issues after serpentine belt change help
    Jan 2006
    Near Basingstoke
    1.9TDi AWX. Have got reconditioned OEM (valeo) alternator. Clutch definitely siezed on old one, turned ok in both directions but didn't slip. Haven't re-fitted yet as bug**ring around with thermostat first
  6. Re: Alternator and power steering issues after serpentine belt change help
    Aug 2011
    Meath
    You might need some cream for skinned knuckles if you don't pull the lock carrier forward
  7. Re: Alternator and power steering issues after serpentine belt change help
    Jan 2006
    Near Basingstoke
    yes managed to get the alternator off no problem without resorting to lock carrier position, but lets see how we go with re-assembly. Looks like it's going to be difficult to hold 19mm ring spanner with one hand and do belt with other...or should I but belt on alternator then hold tensioner while putting viscous fan back on. Expect cursing, especially as it all came apart so easily
  8. Re: Alternator and power steering issues after serpentine belt change help
    Pembrokeshire
    22 Post(s)
    once you know how to do the front, it takes 20 mins tops. that 20 mins will save so much hassle down the line. just do it....
    1 1 0
  9. Re: Alternator and power steering issues after serpentine belt change help
    Jan 2006
    Near Basingstoke
    Replacement alternator arrived from Schmitz_RE in Birmingham. Is indeed a genuine valeo fully reconditioned (looks new to me) at £78 including next day delivery, fitted and all working great. Probably could have just done the pulley but by time bought pulley, spline tools etc I decided the extra £40 odd was worth it to get a fully reconditioned unit with a years warranty. Changed thermostat (genuine VW) at same time and that seems to have sorted the low temp issue so all good.
    PS....No skinned knuckles, couldn't believe how easily it all came apart and went back together without resorting to service position.. Thanks everyone for the advice
  1. Question 1.9tdi (130) power steering pump & alternator belt tensioner problems.......
    By jw signs in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-04-2013, 10:03 PM
  2. Serpentine Belt & Alternator
    By OddBallBoy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 28-11-2012, 09:17 PM
  3. Question POLO 1.9 SDI Twist power loss after change of alternator and fan belt
    By paragkachare in forum Polo - Derby - Lupo - Fox
    Last Post: 07-12-2009, 03:25 PM
  4. Power Steering/Alternator/Water Pump Drive belt noisey
    By EVO in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 03-11-2009, 06:51 PM
  5. Alternator/Power steering belt replacement?
    By bdev in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 30-03-2009, 10:41 AM
