Thread: BOSE coding
  1. BOSE coding
    My 2012 A6 has BOSE, and is running MMI software 770 (it ws like that when I got it).
    From looking at the internet, everyone seems to report their coding as: 030000 - whereas mine is 010000. Any ideas what difference this makes?
    Code:
    Address 47: Sound System (J525)       Labels: None
       Part No SW: 4G0 035 223 C    HW: 4G0 035 223 A
       Component: BOSE-G3-C7    H07 0160
       Revision: CJ007000    Serial number: 00000000023294
       Coding: 010000
       Shop #: WSC 40404 001 1048576
       VCID: 1D31240404102FC964D-8048
    No fault code found.
  2. Re: BOSE coding
    46 Post(s)
    Takes into consideration leather/cloth, diesel/petrol/hybrid, auto/manual, saloon/avant, a6/a7 believe it or not.
    Until Rosstech release a label file you'll not see which bytes do what.
    In the meantime if you have genuine VCDS you can send RT a controller map which will help them develop the label file - Control Module Maps - Ross-Tech Wiki
  3. Re: BOSE coding
    Thanks Chris, I had seen some references to leather/cloth elsewhere. Yes, I have genuine VCDS.
    Should it be OK to change this, or am I likely to trigger component protection?
  4. Re: BOSE coding
    46 Post(s)
    Change what? The control module is mated to your car, even if you remove and plug it back in it'll still work. CP only kicks in if you've installed a replacement module.
  5. Re: BOSE coding
    Change the coding (i.e. experiment).
  6. Re: BOSE coding
    May 2014
    Darlington
    78 Post(s)
    Is the coding from factory? and is there any problems with the sound (speakers not working) If so I would not bother to change it + if it goes in for any warranty work the coding will just be revered back.
  1. bose
    By too577 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-11-2009, 10:44 AM
  2. Please Help Upgrade non bose --> Bose
    By vaslam1986 in forum In Car Entertainment
    Last Post: 21-11-2009, 02:31 PM
  3. Question Bose speaker in non-Bose car
    By SteveCac in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 19-04-2009, 04:32 PM
  4. Bose
    By audipersempre in forum In Car Entertainment
    Last Post: 26-01-2009, 08:55 PM
  5. Bose
    By tlionhart in forum Audi A3 - Archive Topics
    Last Post: 19-11-2008, 05:53 PM
