Thread: ESP and limp mode when cold, VCDS says hpfp valve n276
  1. ESP and limp mode when cold, VCDS says hpfp valve n276
    Oct 2013
    Coventry UK
    Hi guys, I\ve got a little bit of a problem with my B7 recently, just a day after I picked up the car from garage after replacing the chain and tensioner behind the engine, the car started behaving weird.
    On cold engine EPC light comes on and car goes into limp mode unti it reaches 90 degrees then I stop and sytart the engine and it's fine, it doesn't come back till the next morning. Hooked up my VCDS to see if theres any errors and it keeps on giving me this:
    1 Fault Found:
    008852 - Fuel Pressure Regulator Valve (N276)
    P2294 - 004 - Open Circuit - Intermittent
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 172644 km
    Time Indication: 0
    Freeze Frame:
    RPM: 1730 /min
    Load: 69.4 %
    Speed: 35.0 km/h
    Temperature: 59.0°C
    Temperature: 8.0°C
    Absolute Pres.: 1000.0 mbar
    Voltage: 14.351 V
    Obviously went back to the garage and valve and hpfp looks fine. Any ideas please guys?
  2. Re: ESP and limp mode when cold, VCDS says hpfp valve n276
    Jan 2015
    Did you ever fix this ? My audi b7 model 2.0 tdi has limp mode only on a cold engine. As soon as its warmed up I never get limp mode.
    Is this similar to your problem ? Would really appreciate help as had this for a year now and cant find a fix!!!!
  3. Re: ESP and limp mode when cold, VCDS says hpfp valve n276
    Oct 2013
    Coventry UK
    Hi mate, looks pretty much the same, how you had it scanned for faults?
    I think with mine was hpfp the problem as the pressure regulator on top of the hpfp was cracked. Only replaced it two days ago and so far so good mate
  1. ESP and Brake Warning Lights on Dash (Goes into Limp Mode)
    By webtechy in forum Q7 - 4L Forum - 2006 - 2015
    Last Post: 15-07-2014, 12:02 AM
  2. ESP light and limp mode
    By garethdeb1970 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 01-06-2014, 06:33 PM
  3. ESP EPC then Emissions lights. Car in limp mode
    By wobblish in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-05-2012, 02:38 PM
  4. 2.0 FSI ESP Light on AND Limp Home mode.....
    By Super76 in forum Golf MK5 - 2004 - 2009
    Last Post: 20-07-2010, 09:40 PM
  5. limp mode when cold
    By passat 130 tdi in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-11-2009, 06:55 PM
