Thread: SD cards to use in Audi A4 DVD Sat Nav
Page 5 of 5 FirstFirst ... 345
Results 41 to 49 of 49
  1. Re: SD cards to use in Audi A4 DVD Sat Nav
    #41
    Jun 2008
    I have just checked and some of my 'back up' tracks are 192 and working fine.
  2. Re: SD cards to use in Audi A4 DVD Sat Nav
    #42
    Jun 2008
    Manchester
    Yes 192 bit rate should work fine mine work as well.
    I got my 1GB SD card from ebay, came from Hong Kong in a couple of days, didnt even need to format it, just stuck my mp3s on it and it worked first time. One thing to note is that stick with ID3Tag V1 to tag on your tunes as the RNS-E unit picks this up fine.
    I use Winamp to sort all the tags out on my files, it also has the ability to change ID3 tag versions to v1.
    1GB SD Card
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=230275136787
    Ideally you only need one 4GB SD card, as mentioned before the limit is 512 items including songs and folders. Typically on a 4GB card if you rip at 192kbps you can get about 30+ albums each in their own folder. You can fit more if you lower the bit rate but that will compramise sound quality.
    All I do is the following:
    1. Create a folder for each album in the root directory of the SD card
    \Album
    2. Copy all mp3 tracks into corresponding album folders
    3. Order them by track number
    4. Stick it in the RNS-E
    5. Select CD/TV
    6. Select the card - All album folders are displayed
    7. Select what album you want and enjoy.
    For track names, whilst your track is playing select push setup and change preference to display track name.
    Whilst a track is playing you can push the return button which takes you back to your root folder where all your albums are.
    A4 3.0TDIQ S-Line
  3. Re: SD cards to use in Audi A4 DVD Sat Nav
    #43
    Jun 2008
    Nice. I just downloaded ID3tag. Now how do I use it? All I want to do is get rid of track numbers.
    http://www.audio-toolz.de/download.php?id=70001
    How high can the quality go as I have some Linn files that I might try.
  4. Re: SD cards to use in Audi A4 DVD Sat Nav
    #44
    Jun 2008
    Manchester
    Quote Originally Posted by Dougster View Post
    Not sure on that program mate, I use Winamp. There will be a help file with the download look through that.
    A4 3.0TDIQ S-Line
  5. Re: SD cards to use in Audi A4 DVD Sat Nav
    #45
    Aug 2008
    Thanks for the help!
    My playback issues have now been resolved !
    It was a combination of factors apparently:
    - Bit rate higher than 192
    - Wrong tags (mostly with converted Mpeg 4 files including eg cover pictures)
    I use Xilisoft to convert files, works fine. The trial version only allows you to convert 2 files/session, but you can open several sessions simultaneously
  6. Re: SD cards to use in Audi A4 DVD Sat Nav
    #46
    Sep 2008
    Rothwell
    I've just ordered a new A4 SE spec. It doesn't have DVD but it comes with a Concert radio, 'SD memory card reader' and colour screen. I understand that it won't take cards bigger than 2GB but I would like to know is what it will display on the screen - will it show track title, artist genre etc?
  7. Re: SD cards to use in Audi A4 DVD Sat Nav
    #47
    Sep 2007
    Quote Originally Posted by nphnet View Post
    I stand corrected they do say 196MB
    It says 196 because the display only allows for 3 digits. The real figure will be between 1960MB and 1969MB
    I assume they only programmed it to show 3 digits because it was only tested up to 256MB.
  8. Re: SD cards to use in Audi A4 DVD Sat Nav
    #48
    May 2008
    while we r on the subject of SD cards etc for the sat nav plus, does ne one know wot is involved to get the telly and DVD playback option working? I would love these extra toys!
  9. Re: SD cards to use in Audi A4 DVD Sat Nav
    #49
    Jun 2008
    Marmitehampton
    Either an Audi TV unit or an Ebay video unit for about £100...
    2007 Audi A4 2.0 TDI 140PS | S-Line | BOSE | Volterra Leather
    Retrofitted | RNS-E | SDS | Bluetooth | Cruise Control | Parking Sensors | Arm Rest | DIS
  1. Bora TDI door cards
    By redtony in forum Bora - 1998 - 2005
    Last Post: 21-11-2007, 08:36 PM
  2. GT Tdi lock n door cards help !!
    By quaidpinder in forum Chat - Anything with wheels
    Last Post: 11-09-2007, 09:55 PM
