Thread: diy 1.4 122 TSI oil change service
  1. Smile diy 1.4 122 TSI oil change service
    Sep 2012
    St Leonards on Sea, UK
    Some thoughts after having done this service myself.
    Not being keen to crawl around removing the undershield to get at the drain plug a Pela 650 oil extractor was purchased. A metre or two of 4mm x 6mm clear plastic tubing was needed ( £2.55 free p.p. on Ebay)to go down the dipstick tube and connect to the Pela pump. A few strokes of the pump handle and fifteen minutes later 4 litres of the used oil were out.
    The oil filter cartridge was next and on the tsi this is mounted in a very accessible position at the front of the engine. The main dealer had serviced this 15000 mile 2 year old car before delivery and must have employed a gorilla to tighten the filter instead of a torque wrench set to 20Nm. It would not move with a strap wrench up to the point that the canister was beginning to buckle. Then had to order VW tool 3417, fitted it to a half-inch socket bar, and to a sigh of relief it shifted. The new filter's seal was oiled and it was fitted to the correct torque.
    4 litres of Castrol Edge 5W30 and job done.
    Cabin pollen filter and engine air filter changing was straightforward. Brakes were inspected when new tyres were fitted.
    There are some good YouTube videos posted covering most of these steps.
    2 0 0
  2. Re: diy 1.4 122 TSI oil change service
    Southampton, UK.
    As you show, it's surprisingly easy, saves £££'s and gives you a sense of satisfaction!
    2003 VW Golf Est 1.9 TDI 130 (gone but not forgotten after 367,000 miles)
    2006 Audi A3 2.0 TDI Sport 140
  3. Re: diy 1.4 122 TSI oil change service
    Sep 2009
    Stoke on Trent, England
    12 Post(s)
    These oil extractors aren't worth it, you get underneath and use the drain plug.
    No one uses a torque wrench on an oil filter you just oil the mating seal and tighten hand tight.
    2010 Golf GTD (170) CBBB, 5 Door, Shadow Blue (P6/D5Q), Flat Tyre Indicator, Basic Protection Pack + VCDS.
  4. Re: diy 1.4 122 TSI oil change service
    Sep 2012
    Very useful when like me you are 78 years old. VW specify the torque for the filter in the dealer service manual.
  5. Re: diy 1.4 122 TSI oil change service
    Southampton, UK.
    Quote Originally Posted by Keithuk View Post
    These oil extractors aren't worth it, you get underneath and use the drain plug...
    I've been using a Pela for ages and it sucks up virtually all the oil in the sump. At first I was a bit sceptical, so I sucked up the oil first, then dropped the sump plug. This yielded only a few extra drops of oil. IMHO, unless you have a ramp or a pit, I'd much rather use a Pela as it cuts the time needed for an oil change considerably, plus you leave the plug in place and don't have to be concerned about accidentally stripping the alloy sump's thread.
  6. Re: diy 1.4 122 TSI oil change service
    Sep 2012
    Just used the Pela oil extraction pump again on the Golf 1.4 tsi caxa engine. A 30 minute job from start to finish. Loosening the filter cartridge a turn or two and waiting for the oil to flow back into the block is worthwhile and it is essential to use a cloth beneath it to stop any drips onto the poly belt. Have used this pump on three other family cars with success. I have no connection with the manufacturer or suppliers.
  7. Re: diy 1.4 122 TSI oil change service
    Nov 2009
    Otley West Yorks
    If you look at the BMW ranges no sump plugs are fitted
    but I am same as you Old school Like to see the Oil and sludge come out
    Ex Golf Match Now New Leon 1.4 SE SC
  8. Re: diy 1.4 122 TSI oil change service
    Sep 2012
    All VW main dealers use the used oil collection and extraction tool, VAG 1782. Oil comes out via the dipstick tube.
  1. Question Jetta SE 1.4 tsi 122
    By Mike'A in forum Jetta MK3 - 2005 - 2013
    Last Post: 29-01-2013, 11:03 PM
  2. TSI 122 noise
    By Buggslondon in forum Golf MK5 - 2004 - 2009
    Last Post: 09-03-2012, 12:35 AM
  3. 1.4 TSI 122 - economy?
    By mjcon in forum Golf MK6 - 2009 - 2013
    Last Post: 01-06-2010, 04:27 PM
  4. 122 TSI a better engine than 160 TSI?
    By dmw76 in forum Golf MK6 - 2009 - 2013
    Last Post: 02-03-2010, 04:17 AM
  5. Diy Oil Change ?
    By bigwheels280 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-07-2007, 09:46 AM
