Thread: Tow Bar Wiring
Results 1 to 10 of 17
  1. Tow Bar Wiring
    Apr 2007
    Sawtry, Cambs
    2001 2.5tdiA6 Avant quattro
    Just fitted a new bosal tow bar. Anyone found a ignition on, 12V feed to power the bypass board ? I looked at the 12V aux socket but the wiring out the back of it travels in a hard conduit I think. Seems alot of trouble to route power all the way from the batttery as the instructions say.
    Thanks.
    Dave
  2. Re: Tow Bar Wiring
    Dec 2006
    Manchester
    I had to hard wire my bosal towbar all the way back to the battery. Secured it using cable ties.
    A friend of mine got his 12v feed form the side lights (on his focus) so it'd only ever work if the sidelights were switched on. (increased visability makes sense if your towing)
    Nick
    1.9 tdi PD 100 Bora
    110cc pitbike, 4 speed semi-auto
    110cc Off road buggy, 4 speed semi-auto
  3. Re: Tow Bar Wiring
    I can't help, sorry. But I am interested in where you got the towbar and how you fitted it, how much it cost etc?
  4. Re: Tow Bar Wiring
    Apr 2007
    Sawtry, Cambs
    I ordered the bar from The leisure shack. They are on the bay of if you google you will find them. It was just under £130 delivered for the swan neck type. I picked that one as I have park sensors and the necky bit comes off with two bolts and the proper detachable bar a fair bit more to buy. Turns out the park sensors work fine with the bar on and nothing attached anyway.
    Fits a treat. Plastic bumper and ally one have to come off for minor cut outs (templates provided) Very accurate neat fit . If I thought someone was going to ask about a bit of a dull job I would have taken pics.
    I'll get the camera out when I do the cam belt which is the next job.
    Dave
  5. Re: Tow Bar Wiring
    Thanks Dave, I really didn't want to cut the bumper - how does it look? I've seen Golfs with a cut out and it looks crap!
    How long did it take you to fit? Did it come with the electrics too?
    I too am about to change the timing belt, it's not too bad though, just takes time more than anything.
  6. Re: Tow Bar Wiring
    Apr 2007
    Sawtry, Cambs
    Hi, The bumper cut is nothing really. You would have to look hard to find it were the bumper not there. 20mm x 60mm it is. I'll post some pics at the weekend for how it looks.
    Took me a whole morning but I ***** around looking for little jobs to make the time outside last longer, wifey would say. Bit of Jizer here bit of hammerite and waxoil there. I did need to replace both the bumper guides £6.28 plus vat from the ******* as the fixings to bumper had broken off some time in the past. Some sealing rubber washers were missing from the 3 bumper fixings on the out side of the light cluster. I ordered these and they came in as metal ones so the jobs still not finished. Still no electrics wired in yet. It's just the power to the relay board I need to plumb in. Pondering running twin core to the engine bay but seems a bit of a faff.
    Looked at the Autodata run through on the cam belt change and it looks like a good weekend to me although they state 4.5 hrs ! I reckon I'll spend that on cleaning all the bits you would never get to on any other day with bumper off and up in the air. Another good reason for DIY
    Any tips on the belt change would be welcome.
    Sorry forgot to mention, as I already had the electrics so that price is for swan neck bar only.
  7. Re: Tow Bar Wiring
    Jul 2007
    I had mine done at at towbar place in stoke.the electric comes from the back of the 12volt point in the back.it works by switching at 13 volts saves running a cable from the ignition.think you can buy them from towsure called a self switching dule split relay.at £11.25
    hope this helps
  8. Re: Tow Bar Wiring
    Apr 2007
    Sawtry, Cambs
    Thanks for that Digit, Sounds just what I need.
    Dave
  9. Re: Tow Bar Wiring
    hi there, I'm about to fit a detachable westfalia tow bar to my 99a6 avant, this car has no bulb faliure warning lights on the dash so is there any need to fit a bypass relay?
  10. Re: Tow Bar Wiring
    Apr 2007
    Lancashire
    I discovered that my towbar had been fitted by monkeys, and had been wired into the rear light cluters.
    My rear bumper also has an 'alternative' mounting system.
  1. Wiring Problems
    By Jimbo1.8t in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 16-08-2007, 08:38 PM
  2. wiring an amp in a mk4 TDI
    By bigwint in forum Golf MK4 - 1999 - 2004
    Last Post: 16-04-2007, 03:36 PM
  3. Wiring?
    By bromine in forum Passat - Archive Topics
    Last Post: 10-02-2007, 07:33 PM
  4. wiring up an amp in a a3
    By jkruse123 in forum Audi A3 - Archive Topics
    Last Post: 08-12-2006, 03:46 PM
  5. 80 tdi wiring diagram
    By mmatt in forum 80 - 90
    Last Post: 21-10-2005, 01:45 AM
