Thread: Running cold
  1. Running cold
    Oct 2014
    England
    Afternoon all.
    So I drove to Kent last week and noticed that the temp gauge on the dash was reading 80 most of the way (car is a 2005 3.2 by the way!) with slight fluctuations. I'm guessing that my thermostat has stuck open (assuming that the engine should operate at 90-95 degrees, with a stat set at about 88), so the car will be running cold permenantly, which explains why consumption wasn't quite right too.
    Questions are as follows
    1. How hard are they to replace. I've had a quick buthers and they seem to live at the top of the engine, which means in theory I shouldn't dump that much coolant! Is it just as easy as removing the silencers, the inlet manifold and robert is your fathers brother?
    2. Is there a guide to bleeding them anywhere? My previous BMW was a pain to bleed if you didn't know wjhat you were doing.
    3. Is there any other preventative maintenance worth doing whilst the inlet manifold is off?
    Cheers guys!
    Rob
  2. Re: Running cold.......
    Jun 2006
    Hi Rob,
    Stat is on top as you said.
    You should see errors posted in VCDS under engine.
    I had:
    1 Fault Found:
    18613 - Performance Malfunction in Cooling System
    P2181 - 000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00101000
    Fault Priority: 0
    Fault Frequency: 6
    Reset counter: 187
    Mileage: 63262 km
    Time Indication: 0
    Date: 2011.12.22
    Time: 15:10:27
    Freeze Frame:
    RPM: 2080 /min
    Mass Air / Rev.: 223.5 mg/str
    Temperature: 78.0°C
    Part Throttle
    Temperature: 12.0°C
    Speed: 102.0 km/h
    Readiness: 0000 0000
    This was the thermostat being lazy, a new one sorted it. I got an indi to do mine as weather was bad at time.
    Personally, I'd be tempted to put new coolant in. Also you could look to see if you have much carbon build up on the intake valves.
    All the best.
    Andy
  3. Re: Running cold.......
    Aug 2013
    Carlisle Cumbria
    9 Post(s)
    What apole said. Don't forget, modern car temperature gauges aren't really gauges, more customer reassurance devices. They are designed to indicate 90 at a range of temperatures which may be encountered under normal conditions. Stuck open or opening early will give you the symptoms you have. You can log the temperature outputs from cold with VCDS which will show you more about what's going on.
  4. Re: Running cold.......
    Oct 2014
    England
    Gents, thank you both for your the replies. I figured it was the stat failing, I shall get one ordered and swap it out next weekend hopefully. I'll stick VCDS on later to confirm too.
  5. Re: Running cold.......
    Feb 2012
    folkestone.uk
    Hi.
    Don't know if this is too late but if your changing the thermostat get some inlet manifold bolts as they tend to snap when putting them back.
    not a bad job but weather getting too cold for me. If you need mor info give me a shout.
    Dave
  1. Cold running help
    By macp in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 24-09-2011, 10:13 PM
  2. Running cold..
    By polodub in forum Polo - Derby - Lupo - Fox
    Last Post: 09-12-2010, 12:29 PM
  3. Audi 80 cold running problems
    By peter4728 in forum 80 - 90
    Last Post: 29-01-2009, 12:12 AM
  4. 1993 TD Running cold
    By nielsfjords in forum Passat - Archive Topics
    Last Post: 28-01-2007, 11:15 PM
  5. A6 running cold but temp warning ??
    By sumbuddy in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 12-12-2006, 03:50 PM
