Thread: maybe new cluych needed soon
  1. maybe new cluych needed soon
    Oct 2013
    belfast
    been driving the car month or so. since ive noticed a judder whilst taking of from the bitting point on clutch. only does it when car is being drove for about 45 mins. youd think somone had took a kango hammer to the car when it starts. also this only happens in first gear no others. is this a sign the clutch is ready to go. or is there anything else i can check before good money is spent
  2. Re: maybe new cluych needed soon
    Jan 2009
    Birmingham
    36 Post(s)
    Mine does it sometimes aswell I don't think your clutch going îf it does not slip then your ok I think it could be moisture on the clutch plate causing the judder then soon as it dries up the judder goes I sure new clutch are modified so you don't get moisture accumulating on the plate
  3. Re: maybe new cluych needed soon
    Aug 2011
    Meath
    Flywheel
  4. Re: maybe new cluych needed soon
    Jan 2009
    Birmingham
    36 Post(s)
    Could be flywheel are you getting any violent starts and does it shudder when you turn off engine any rubbling sound at idle press the clutch in and out any change in noise what's the milage on the car has it ever had a clutch or flywheel change before
  5. Re: maybe new cluych needed soon
    Oct 2013
    belfast
    dont forget this judder doesnt happen when car is cold. this judder starts playing up when the is warm the longer its drove the more judder. the clutch isnt slipping at all. not sure if this means anything. but when it started to judder it felt like it was coming from drivers side wheel or in and around that area. could this be drive shaft ?????
  6. Re: maybe new cluych needed soon
    Jan 2009
    Birmingham
    36 Post(s)
    flywheel
  7. Re: maybe new cluych needed soon
    Oct 2009
    Ashford Kent s,e England
    10 Post(s)
    DMF, just google these flywheels or forum search, if it is the DMF you will need a clutch kit aswell, won't be too cheap
  1. New To Forum - Help With New A4 Needed - HELP NEEDED
    By lbaldy14 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-10-2014, 11:03 AM
  2. Help needed
    By Frasermax in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-09-2010, 08:37 PM
  3. Hello All - A3 Help Needed
    By madmover in forum New Member Introductions
    Last Post: 01-06-2010, 08:28 PM
  4. Help needed!!
    By veedubbora07tdi in forum Bora - 1998 - 2005
    Last Post: 30-07-2008, 02:10 PM
  5. A3 help needed
    By squinty in forum Archive posts
    Last Post: 28-05-2007, 04:46 PM
