Thread: Confirmation N75 1K0906627B Sensor Connections 1.4 TDI
  1. Confirmation N75 1K0906627B Sensor Connections 1.4 TDI
    Dec 2014
    chelmsford essex
    Hi Group
    As I am having problems fixing a P0243 fault, I wanted to check the connections to the N75 sensor part number 1K09062B.
    Could someone please confirm which air hose should go to each of the three connections on the N75 sensor, from left to right with reference to the attached a photo of the N75 which I hope people can see, The black connection left, the outer white connection middle and the center white connection right on the attached photo?
    I have previously tied to clear the P0243 fault by replacing the N75 sensor and turbo actuator.
    Help appreciated
    Iain
  2. Re: Confirmation N75 1K0906627B Sensor Connections 1.4 TDI
    May 2007
    17 Post(s)
  3. Re: Confirmation N75 1K0906627B Sensor Connections 1.4 TDI
    Dec 2014
    chelmsford essex
    Hi Flash2
    Thanks for your diagram
    I Checked the three hose to N75 Sensor today, and they were connected in the right order.
    Both the N75 sensors measured 15 ohms when disconnected to the electrical plug.
    Will have a look at the wiring tomorrow.
  1. Question please can someone check the connections on the boost controller (newer n75 valve)
    By cusford in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 09-06-2011, 11:19 PM
  2. n75 sensor
    By geo_855 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 22-04-2011, 12:18 AM
  3. map sensor or n75 valve
    By d king in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-04-2009, 06:29 PM
  4. what is the function of the N75 sensor
    By Don_passat98 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-03-2008, 12:27 AM
  5. N75 valve connections
    By dreamworx in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 18-12-2006, 05:52 PM
