Thread: Indicator problem
  1. Indicator problem
    Dec 2014
    Hi all,
    I'm new here, hope someone might be able to help. Car is a A6 C5 2005 1.9TDI avant final edition .
    Got a problem with the indicators - indicating left works fine, but indicating right - nothing happens.
    It's not the bulbs as they work fine (lamps and dashboard) with the hazards and the immobiliser.
    I don't think it's the indicator stalk either, sd with the keys out and the indicator set to 'right', the rhs parking/side lights come on no problem.
    A quick google seems to indicate it might be the hazard light switch that's faulty, but I wondered if anyone knew otherwise?
    Cheers!
  2. Re: Indicator problem
    Ayrshire, Scotland
    18 Post(s)
    yep, I would have said stalk, but the parking lights working indicate it should be ok, so hazard relay is next, it controls the indicators also
    best regards
    Andy
    2001 Audi A4 Saloon 2.0
    2000 Audi Allroad 2.5TDI V6 quattro
    Fully licenced Ross-Tech VCDS Interface
    Air Suspension Compressor Repair Kits: www.bagpipingandy.com
  3. Re: Indicator problem
    Feb 2011
    Sutton Coldfield England
    Indicating to turn right is used more often than indicating to turn left
    That means more wear on the switch contacts for that side
    Put the indicator stalk to the right a few times in rapid sucession and you may clean the contacts
    Failing that I think you may need a new switch
    You could try squirting switch cleaner int the area of the switch it can work ( use Isoproponal )
    Hope this helps
    BobH
  4. Re: Indicator problem
    Pembrokeshire
    22 Post(s)
    bob, he says the parking lights work fine which will rule out the stalk, so it must be the hazard switch, as thats a common part to be replaced.
    also, both sides of the indicators must be used an equal amount, or you would never get back to where you started from, would you ? think about it... haha
  5. Re: Indicator problem
    Dec 2014
    Hmmm so I got a replacement hazard relay, popped it in and... same problem!
    Will try blasting some contact cleaner in the switch but as I said earlier, I don't think it's that as the park light still works when the keys aren't in the ignition.
    Unless there are separate switch contacts for indicator and parking lights in the stalk switch?
    Can anyone point me to a schematic/circuit diagram of the indicator stalk switching to see what it actually does?
  6. Re: Indicator problem
    Feb 2011
    Parking lights and indicator lights are on different contacts within the switch
    There are two relays in the Hazard switch module, one for the turn signals and the other for Hazzard lights
    Its a fact that RH turns are more frequent on RHD cars and left turns more frequent on LHD cars
  7. Re: Indicator problem
    Is your car a 4B2 C5 or what exactly. The were major changes in late 2005. Regards Peter
  1. indicator problem
    By vwnige in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-10-2012, 10:19 PM
  2. Indicator Problem
    By Hembrowr in forum Polo - Derby - Lupo - Fox
    Last Post: 28-02-2010, 07:40 PM
  3. A4 Indicator problem
    By saquince in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 15-02-2010, 11:28 PM
  4. A6 Indicator Problem
    By markormiston in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 29-09-2008, 07:05 PM
  5. Indicator Problem - help!
    By winker in forum Audi A3 - Archive Topics
    Last Post: 26-09-2008, 11:49 AM
