Thread: 2.5 TDi V6 (BDG) Timing help
  1. 2.5 TDi V6 (BDG) Timing help
    Oct 2014
    salford
    Ok i am using Elsawin and VCDS to adjust timing however i have some problems with what Elaswin states and what i have encountered.
    I get the engine up to temp then using VCDS i go to engine settings and group 4, then i switch to 'basic setting' which makes the engine change sounds. Then i look at VCDS when it cylces through late and early and expect to 0% and 100% in the last box (cold start valve) when it cycles but it only moves between 15% and 85% (cold start valve)
    What is this and why is it not opening and closing fully? Is it thE EGR valve?
    Can i still do the timing with these values?
    The late cycle shows ATDC value of 5 moves up and down slightly between 4.6 and 5.2 which i belive should be around 2
    The early cylce shows ATDC value of 12 ish
    Am i getting false readings from the ATDC because the Cold start valve is not opening and closing fully?
    Thanks people
  2. Re: 2.5 TDi V6 (BDG) Timing help
    May 2008
    I had a go at this recently having replaced my fuel pump... I followed the Ross tech guidance for VCDS and despite being a novice I'm sure it's spot on! Car runs great and like you it's a BDG. TDIGraph - TDI Timing Checker
  1. A6 c5 BDG Engine Headlamp Ballast
    By bobh6742 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-01-2014, 06:53 PM
  2. 2.5 TDi BDG 4B5 2003 4th Alternator
    By Seanious in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-11-2013, 11:46 PM
  3. Replacing aircon fan on BDG Engine
    By bobh6742 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 13-10-2013, 07:58 PM
  4. 2.5 v6 tdi timing
    By bertle in forum VCDS - General Questions
    Last Post: 07-12-2010, 11:37 PM
  5. A4 1.9 tdi timing
    By ginganinja in forum 1.9TDi - Engine
    Last Post: 03-10-2010, 10:51 PM
