Thread: 2003 Audi A4 Avant 2.0 FSI EPC Problem
Results 1 to 8 of 8
  1. 2003 Audi A4 Avant 2.0 FSI EPC Problem
    Nov 2014
    Retford
    Hi, I'm hoping someone can help me find the cause of the epc light coming on when I'm driving, this only happens occasionally but when it does happen, the car loses power and cannot accelerate, goes off after a few seconds but comes back on intermittently. Please help!!!!!!
  2. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    46 Post(s)
    Have you had it scanned by a VW/Audi specialist?
  3. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    Nov 2014
    Retford
    No I haven't, was hoping someone may have an idea what it could be so I could check it out myself before it gets expensive
  4. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    46 Post(s)
    It could be anything. On a modern car you simply can't guess whats wrong .
  5. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    Pembrokeshire
    22 Post(s)
    it could be the maf, so change that first, if that doesn't solve it then replace the coolant temp sensor. if that doesn't work then replace all the coil packs as it could be them, if thats doesn't work then replace the throttle body, then replace the fuel pump, then the cam sensor, then i would try a new set of injectors, a lambda sensor and a cat. if the epc light is still on then sorry, i am out of ideas and you will need to get a code readout, but thats expensive , so avoid that at all costs.
    0 2 0
  6. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    Nov 2014
    Retford
    Best place to buy the maf from?
  7. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    Pembrokeshire
    22 Post(s)
    get a code read first pal.
    you should recognise sarcasm on this forum by me.
  8. Re: 2003 Audi A4 Avant 2.0 FSI EPC Problem
    May 2007
    17 Post(s)
    LOL...oh, and welcome to the forum bye the way Paigey.
  1. AUDI A4 avant 2003 1.9tdi Dashboard Instrument Cluster problem
    By smithmat in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-04-2014, 02:45 PM
  2. Please Help Australian VW Polo 2003 EPC light problem
    By Des Richards in forum Polo - Derby - Lupo - Fox
    Last Post: 03-01-2014, 12:00 AM
  3. Problem with signal indicator Audi A6 Avant 2003 Reg
    By semen in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-07-2013, 04:24 PM
  4. Please Help 2003 A4 Avant 2.0 FSI - head gasket?
    By Benyon in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 29-08-2012, 10:46 PM
  5. Please Help Audi A4 2.0 FSI EPC Warning Light/Engine Cuts Out
    By fairyliquidizer in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 30-10-2010, 07:19 PM
