Thread: Diagnostic Output
  1. Diagnostic Output
    Apr 2013
    Surrey
    Hi All,
    Been loitering for a while and would like to seek your thoughts on the following areas.
    I have a rain/auto light sensor fault so the sensor has been replaced. Now Audi are telling me that because it's not a genuine Audi screen that may be the cause behind it. Sounds like tosh to me but I've been wrong before...
    I have also noticed some other error codes and would like your thoughts on these to.
    Thank you!
    Code:
    Thursday,20,November,2014,07:49:43:21218
    VCDS -- Windows Based VAG/VAS Emulator
    VCDS Version: 12.12.3.0
    Data version: 20140822
    VIN: WAU*   License Plate: **** ***
    Mileage: 321710km-199901mi   Repair Order:
    Chassis Type: 4F (4F0)
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 19 37 42 46 47 4F 52 53 56
              61 62 72 77
    VIN: *   Mileage: 321710km/199901miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: Malfunction 0010
    05-Acc/Start Auth. -- Status: OK 0000
    07-Control Head -- Status: Malfunction 0010
    0E-Media Player 1 -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    37-Navigation -- Status: Malfunction 0010
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: Malfunction 0010
    77-Telephone -- Status: OK 0000
    Address 01: Engine        Labels: Redir Fail!
       Part No SW: 03G 906 016 GC    HW: 03G 906 016 GC
       Component: R4 2,0L EDC G000CG  9887
       Revision: --H02---    Serial number:
       Coding: 0000076
       Shop #: WSC 00732 210 91799
       VCID: 6AD1E9B3452D0B4E259-803F
    1 Fault Found:
    005512 - Engine Mount Solenoid Valves (N144/N145)
                   P1588 - 000 - Open Circuit - Intermittent
                 Freeze Frame:
                        Fault Status: 00100000
                        Fault Priority: 3
                        Fault Frequency: 4
                        Reset counter: 255
                        Mileage: 321040 km
                        Time Indication: 0
                        Date: 2014.10.05
                        Time: 14:11:33
                 Freeze Frame:
                        RPM: 819 /min
                        Speed: 8.0 km/h
                        Load: 0.0 %
                        Voltage: 13.91 V
                        Bin. Bits: 00101011
                        Torque: 168.4 Nm
                        Torque: 0.0 Nm
    Readiness: 0 0 0 0 0
    Address 02: Auto Trans        Labels: 01J-927-156.lbl
       Part No SW: 4F1 910 155 H    HW: 01J 927 156 JG
       Component: V30 01J 2.0l PD RdW 0020
       Revision: --H02---    Serial number: 00000000000066
       Coding: 0000001
       Shop #: WSC 02325 785 00200
       VCID: 2855D3BB9BA1F95EF3D-807D
    1 Fault Found:
    18201 - Transmission Output Speed Sensor 2 (G196)
                P1793 - 000 - No Signal
                 Freeze Frame:
                        Fault Status: 01110000
                        Fault Priority: 0
                        Fault Frequency: 254
                        Reset counter: 255
                        Mileage: 313206 km
                        Time Indication: 0
                        Date: 2013.08.06
                        Time: 12:11:09
                 Freeze Frame:
                        RPM: 992 /min
                        RPM: 70 /min
                        (no units): 9.0
                        Torque: 24.0 Nm
                        Temperature: 53.0∞C
                        T.B. Angle: 0.0∞
                        Bin. Bits: 0110 0 0
    Address 03: ABS Brakes        Labels: 4F0-910-517.lbl
       Part No SW: 4F0 910 517 K    HW: 4F0 614 517 K
       Component: ESP 8.0 front   H05 0090
       Revision: 00000000    Serial number: 00000000000000
       Coding: 0020856
       VCID: 2C5D2FAB8F59D57E175-8079
    No fault code found.
    Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
       Part No SW: 4F0 910 852     HW: 4F0 905 852 B
       Component: FBSAUDIC6 ELV   H31 0220
       Revision: 31050601    Serial number: 10604000338500
       Coding: 0000147
       Shop #: WSC 00508 210 91413
       VCID: E3CF04972207DA0666F-80B6
       Subsystem 1 - Part No: 4F0 910 131 E
       Component: FBSAUDIC6 EZS   H45 0080
       Subsystem 2 - Part No: 4F0 910 220 D
       Component: FBSAUDIC6 IDG   H39 0040
    Address 07: Control Head        Labels: 4F0-910-7xx-07-H.lbl
       Part No SW: 4F0 910 732 S    HW: 4E0 035 729
       Component: Interfacebox    H43 5150
       Revision: 00000000    Serial number: 350CV067657818
       Coding: 0001002
       Shop #: WSC 02335 785 00200
       VCID: 336F34D752678A8656F-8066
       Subsystem 1 - Part No: 4F0 910 609 E
       Component: Bedienteil MMIC6H03 0050
       Subsystem 2 - Serial number: 00000000356540
       Subsystem 3 - Serial number: 0107.03.060000000100010314ˇ
       Subsystem 4 - Serial number: 010314ˇ
    1 Fault Found:
    02244 - Button in Control Head is Stuck
                000 - - - Intermittent
                 Freeze Frame:
                        Fault Priority: 5
                        Fault Frequency: 2
                        Reset counter: 12
                        Mileage: 320467 km
                        Time Indication: 0
                        Date: 2014.08.07
                        Time: 08:11:47
                 Freeze Frame:
                        Bin. Bits: 00000000
                        Bin. Bits:  0000000
                        Bin. Bits:      001
    Address 08: Auto HVAC        Labels: 4F0-910-043.lbl
       Part No SW: 4F0 910 043     HW: 4F2 820 043 H
       Component: KLIMABETAETIGUNGH12 0170
       Revision: 00000030    Serial number: 00000000240664
       Coding: 0001300
       VCID: DBBF3C771A77E2C62EF-808E
    Address 09: Cent. Elect.        Labels: 4F0-910-279.lbl
       Part No SW: 4F0 910 279 D    HW: 4F0 907 279
       Component: ILM Fahrer      H15 0190
       Revision: 00000000    Serial number: 4F0907279
       Coding: 0001101
       VCID: 2A5129B385ADCB4EE59-807F
       Subsystem 1 - Part No: 4F2 910 113   Labels: 1KX-955-119.CLB
       Component: Wischer AudiC6  H04 0150
       Coding: 00062736
       Shop #: WSC 02335
       Subsystem 2 - Part No: 8K0 910 557   Labels: 8K0-955-559.CLB
       Component: REGENLICHTSENSORH04 0003
       Coding: 00150317
       Shop #: WSC 02335
    1 Fault Found:
    01520 - Rain and Light Recognition Sensor (G397)
                 Freeze Frame:
                        Fault Status: 00100100
                        Fault Priority: 2
                        Fault Frequency: 6
                        Reset counter: 50
                        Mileage: 262136 km
                        Time Indication: 0
                        Date: 2014.11.19
                        Time: 20:07:00
    Address 0E: Media Player 1        Labels: 4E0-910-111.lbl
       Part No SW: 4E0 910 111 F    HW: 4E0 035 111 A
       Component: CD-Changer      H44 0470
       Revision: 00000000    Serial number: AUZ5ZBF8072534
       Shop #: WSC 00000 000 00000
       VCID: 1C3DFF6BDFF925FE675-8049
    Address 15: Airbags        Labels: 4F0-910-655-8R.lbl
       Part No SW: 4F0 910 655 E    HW: 4F0 959 655 B
       Component: 4E AIRBAG AUDI8RH29 0280
       Revision: 08H29000    Serial number: 0037LD0DAK56
       Coding: 0013381
       VCID: 2953D6BF80ABC056EC3-807C
       Subsystem 1 - Serial number: 6332CSME100D3D360
       Subsystem 2 - Serial number: 6342CSME100B2149X
       Subsystem 3 - Serial number: 6352QSME0B62324BG
       Subsystem 4 - Serial number: 6362QSME0B792F79
       Subsystem 5 - Serial number: 63734SME094C0C3DB
       Subsystem 6 - Serial number: 63834SME0B2E1C4BE
    Address 16: Steering wheel        Labels: 4F0-910-549.lbl
       Part No SW: 4F0 910 549     HW: 4F0 953 549 A
       Component: Lenks‰ulenmodul H07 0230
       Revision: 00H07000    Serial number: 90026060540174
       Coding: 0102142
       Shop #: WSC 02323 785 00200
       VCID: E6C91D83D135AF2E811-80B3
       Subsystem 1 - Part No: XXXXXXXXXXX
       Component: Lenkradmodul    H07 0090
    Address 17: Instruments        Labels: 4F0-910-xxx-17.lbl
       Part No SW: 4F0 910 930 A    HW: 4F0 920 980 M
       Component: KOMBIINSTR. M73 H17 0660
       Revision: 00200000    Serial number: 4PX30A036
       Coding: 2304443
       Shop #: WSC 01160 210 57379
       VCID: 2143CE9FF89B0816B43-8074
    Address 19: CAN Gateway        Labels: 4F0-910-468.lbl
       Part No SW: 4F0 910 468 A    HW: 4F0 907 468 D
       Component: Gateway         H11 0070
       Revision: 11          Serial number: 13008062248048
       Coding: 6CFE53C41B3104
       Shop #: WSC 02334 785 00200
       VCID: 2757D08796BFF626FA7-8072
    Address 37: Navigation        Labels: 4E0-910-88x-37.lbl
       Part No SW: 4E0 910 888 P    HW: 4E0 919 887 D
       Component: MNS ECE         H47 1060
       Revision: 00000000    Serial number: 364CX067537269
       VCID: 3B7F1CF77A3742C68EF-806E
    1 Fault Found:
    02261 - Data Medium
                014 - Defective - Intermittent
                 Freeze Frame:
                        Fault Status: 00101110
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 43
                        Mileage: 321426 km
                        Time Indication: 0
                        Date: 2014.10.31
                        Time: 16:46:26
                 Freeze Frame:
                        Hex Value: 0x5453
                        Hex Value: 0xBCE2
                        Hex Value: 0x1A00
                        Hex Value: 0xA3FE
    Address 42: Door Elect, Driver        Labels: 4F0-910-793-42.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 793 E
       Component: TSG FA          H12 0120
       Revision: 00-00000
       Coding: 0003610
       Shop #: WSC 02327 785 00200
    Address 46: Central Conv.        Labels: 4F0-910-289.lbl
       Part No SW: 4F0 910 289 G    HW: 4F0 907 289 G
       Component: Komfortgeraet   H22 0170
       Revision: 01700022    Serial number: 01011226290000
       Coding: 0000763
       Shop #: WSC 00508 210 06808
       VCID: 2E5925A3B945A76E391-807B
       Subsystem 1 - Part No: 1K0 951 605 C
       Component: LIN BACKUP HORN H03 1301
       Subsystem 2 - Part No: 4F0 910 177
       Component: Innenraumueberw.H01 0020
    Address 47: Sound System        Labels: 4F0-910-223-AS.lbl
       Part No SW: 4F0 910 223 G    HW: 4F0 035 223
       Component: Amp.-ASK        H10 0350
       Revision: 34S00001    Serial number: 02802060232026
       Coding: 0000103
       VCID: 2241C193FD9D130EAD9-8077
    Address 4F: Centr. Electr. II        Labels: 4F0-910-280.lbl
       Part No SW: 4F0 910 280     HW: 4F0 907 280 A
       Component: ILM Beifahrer   H10 0080
       Revision:             Serial number: 00000000200426
       Coding: 0001104
       VCID: DEB935630965F7EE491-808B
    Address 52: Door Elect, Pass.        Labels: 4F0-910-793-52.lbl
       Part No SW: 4F0 910 793 E    HW: 4F0 959 792 E
       Component: TSG BF          H12 0120
       Revision: 00-00000
       Coding: 0003610
    Address 53: Parking Brake        Labels: 4F0-910-801.clb
       Part No SW: 4F0 910 801 A    HW: 4F0 907 801
       Component: EPB  CA3C0040   H03 0040
       Revision: --H03---
       Coding: 0000131
       Shop #: WSC 02324 785 00200
       VCID: 1E39F563C9E537EE891-804B
    Address 56: Radio        Labels: 4E0-910-541.lbl
       Part No SW: 4E0 910 541 Q    HW: 4F0 035 541 E
       Component: TUNER EU/US/RDW H42 0620
       Revision: 00000000    Serial number: 352CO067628532
       Coding: 0000001
    Address 61: Battery Regul.        Labels: 4F0-910-181.lbl
       Part No SW: 4F0 910 181 E    HW: 4F0 915 181 A
       Component: J0644 BEM       H12 0590
       Revision: 00000000    Serial number: 00000000031820
       Shop #: WSC 00508 210 59464
       VCID: 234FC497E2871A06A6F-8076
       Subsystem 1 - Part No: 4F0 915 105 C
       Component: von VA0  VA0629T14Y
       Coding: 344630393135313035432056413056413036323954313459
       Shop #: WSC 00732 210 82942
    5 Faults Found:
    02272 - Quiescent Current Stage 1
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 19
                        Reset counter: 255
                        Mileage: 313984 km
                        Time Indication: 0
                        Date: 2013.09.10
                        Time: 02:07:43
    02273 - Quiescent Current Stage 2
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 15
                        Reset counter: 255
                        Mileage: 313984 km
                        Time Indication: 0
                        Date: 2013.09.10
                        Time: 02:14:10
    02276 - Quiescent Current Stage 5
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 11
                        Reset counter: 255
                        Mileage: 313984 km
                        Time Indication: 0
                        Date: 2013.09.10
                        Time: 04:55:05
    02256 - Quiescent Current
                001 - Upper Limit Exceeded - Intermittent
                 Freeze Frame:
                        Fault Status: 00100001
                        Fault Priority: 7
                        Fault Frequency: 1
                        Reset counter: 35
                        Mileage: 321142 km
                        Time Indication: 0
                        Date: 2014.10.19
                        Time: 00:54:41
    02277 - Quiescent Current Stage 6
                 Freeze Frame:
                        Fault Priority: 7
                        Fault Frequency: 10
                        Reset counter: 255
                        Mileage: 317995 km
                        Time Indication: 0
                        Date: 2014.03.12
                        Time: 07:13:55
    Address 62: Door, Rear Left        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 795 E
       Component: TSG HL          H21 0050
       Coding: 0003074
    Address 72: Door, Rear Right        Labels: 4F0-910-795.lbl
       Part No SW: 4F0 910 795 E    HW: 4F0 959 794 E
       Component: TSG HR          H21 0050
       Coding: 0003074
    Address 77: Telephone        Labels: 4E0-910-336.lbl
       Part No SW: 4E0 910 336 M    HW: 4E0 862 335
       Component: Handyvorb2      H16 1130
       Revision: 00000000    Serial number: 00000007645555
       Coding: 0010920
       Shop #: WSC 00508 210 91414
    End   ---------------------------------------------------------------------
  2. Re: Diagnostic Output
    Sep 2008
    mostly in the garage
    there's some indication of low voltage ........has the battery been disconnected? if not check battery condition
  3. Re: Diagnostic Output
    Jul 2013
    76 Post(s)
    Check if it's working using the measuring blocks.
    09 central 1 block 19
    Last edited by Guest 2; 23-11-2014 at 05:01 PM. Reason: link removed - copyrighted info
    Dan
    2009/2010 2.0 TDIe SE
  4. Re: Diagnostic Output
    Apr 2013
    Surrey
    Thanks for the replies!
    The battery hasn't been touched for ages and we've had no problems with it to date.
    Measuring blocks Dan?
    Is this something I could address myself or does it require specialist tools/ramps?
    1 Fault Found:
  5. Re: Diagnostic Output
    Jul 2013
    76 Post(s)
    If you have a genuine Ross Tech VCDS lead then you can view the live data via the measuring blocks.
    Dan
  6. Re: Diagnostic Output
    Apr 2013
    Surrey
    I don't Dan, the AutoElectrician who came to look at the wiper issue saved this to a USB for me.
  1. A/C Output test - ?
    By Novica in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2013, 01:33 PM
  2. Question Output test
    By megger in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 12-07-2009, 02:33 PM
  3. Question Output test
    By megger in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-07-2009, 02:24 PM
  4. power output
    By goodersthea in forum Bora - 1998 - 2005
    Last Post: 10-05-2009, 12:15 PM
  5. Power output
    By A6TDI- quattro in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 02-12-2007, 10:23 PM
