Thread: Bkd timing belt
  1. Bkd timing belt
    Nov 2014
    durham
    Hi All. First off apologies if wrong section I'm on taptalk and new to forum
    I have a Bkd mk5 golf 140hp timing belt due. I've been quoted following all genuine parts
    Timing belt tensioner and pulleys 365
    I also asked for prices on following
    Alternator belt 20
    Alternator pulley 85(if needed)
    Thermostat 40-65
    Is it worth doing the thermostat alternator belts and pulley. The car is getting a full coolant change when timing belt done. No heating issues atm
    I could do them at a later date if needed just need to know if it's worth doing. Car is currently booked in Monday for job
  2. Re: Bkd timing belt
    Pembrokeshire
    22 Post(s)
    you want a new water pump as well, pointless doing the belt and not doing the pump. the alternator belt has to come off, so pointless putting the old one back on. the alternator pulley, thats easy enough to do unless it is siezed now, and the stat is easy enough to do as well, so i would leave the stat and pulley and just do the belt and kit, waterpump and alt belt. the coolant needs draining to do the pump so thats that taken care of.
  3. Re: Bkd timing belt
    Nov 2014
    durham
    Sorry the price for timing belt job is timing belt new water pump coolant change pulleys and tensioner
    Don't think u have any existing issues with my alternator at the moment but I may get the belt done and the alternator belt as it only adds another 20
    Thanks for clarification. The original job when quoted was the kit and the person said the alt belt adds another 20 to it to so I'll do them
  4. Re: Bkd timing belt
    Pembrokeshire
    22 Post(s)
    20 is just the price of the belt, no extra labour as its off anyway, so silly not to do it.
  5. Re: Bkd timing belt
    Nov 2014
    durham
    I would think so but I've heard good and bad things about the garage my brother can do it but I'd rather have the warranty of a garage so they're liable if anything goes wrong
  6. Re: Bkd timing belt
    Pembrokeshire
    22 Post(s)
    they are easy enough to do, a bit tight and fiddly and you must use the right locking tools and use the right coolant afterwards, and everything must be torqued up properly. if you don't trust the garage then don't use them, simple as that.
  7. Re: Bkd timing belt
    Nov 2014
    durham
    I have no basis to trust them because I've never used them before I'm still going to them. End of the day if my car is damaged they will pay for it. Thanks for the help
  1. 2.0 ltr BKD diesel engine Timing locking pin problem
    By oldandbald in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 29-04-2014, 08:02 PM
  2. Replies: 4
    Last Post: 29-04-2014, 04:47 PM
  3. Question 2006 1.6 FSI SE - Timing Belt or Timing Chain?
    By wddonalds in forum Golf MK5 - 2004 - 2009
    Last Post: 04-02-2010, 05:44 PM
  4. Changing the timing belt and drive belt on Audi A6
    By Robbromilow in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 10-09-2009, 08:00 PM
  5. Cam belt timing belt tip , general
    By Conradvw in forum Archive posts
    Last Post: 11-01-2007, 04:29 PM
