Thread: New Polo classic 99 SDI AEY engine- general maintenance questions
  1. New Polo classic 99 SDI AEY engine- general maintenance questions
    Nov 2014
    Israel
    Hi All,
    This is our first VW. I also own a hilux which I DIY as much as i can. It will also be the first time I have to deal with an ECU. After reading info for the last two weeks I understand I will probably need a few things to help me maintain and repair the car:
    -Workshop manual: Haynes doesn't carry manuals for this model or engine so guess I will need to get the Elsawin?Good idea?Any others?
    -A Vag-com? Is it relevant to this model? I want to be able to read faults and data as well as programming the ECU when ever needed. Is the socket OBD1?How is it done?
    Im planing on keeping this car on the long run so I dont really mind making an initial investment for the proper tools needed to deal with it.
    Any other ideas, suggestions and comments will be greatly appreciated.
    Thanks and all the best,
    YTK
  2. Re: New Polo classic 99 SDI AEY engine- general maintenance questions
    Sep 2009
    London/Bucks England
    Vag-com or VCDS is well worth having if you plan to keep it running. Should be an obd-II socket. but the OBD-I variety share the same socket on these cars. You will be able to get adapters for the sockets if there is anything special happening anyway.
    I wouldnt worry about VCDS unless you have a problem, you need a laptop to run it on also.
    If you have the cash and everything ready then go for it. Its a must have tool for my DIY at least.
    151 PS @ 3800 rpm 1.6 8V MPi - 31.5mpg urban <-- Happy days
    123k On the clock and counting. (25k on the block)
    I need all your V-Powers.
    1 1 0
  3. Re: New Polo classic 99 SDI AEY engine- general maintenance questions
    Nov 2014
    Israel
    Thanks for that! I am going to get a Vag com with a vcds . Still trying to understand if there is a legitimate way to get a workshop manual .
    YTK
  4. Re: New Polo classic 99 SDI AEY engine- general maintenance questions
    Aug 2011
    Meath
    NEW HAYNES WORKSHOP MANUAL FOR SEAT IBIZA & CORDOBA 93-99 PETROL & DIESEL - 3571 | eBay
    Halfords professional sockets and spanners are excellent for occasional DIY and servicing. Cordoba is basically a polo. A cheap fault code reader is all you need, the OBD socket is on the LHS when you open the glove box under the steering wheel. You can't legally own Elsawin unless youre a dealer
  5. Re: New Polo classic 99 SDI AEY engine- general maintenance questions
    Nov 2014
    Israel
    Thanks for that but when I wrote Haynes a couple of month back they replied there is no current manual for that specific engine model
  6. Re: New Polo classic 99 SDI AEY engine- general maintenance questions
    Aug 2011
    Meath
    You would find that engine in a Golf, Bora, Octavia, Caddy, Inca, Cordoba etc the other stuff like brakes, suspension etc is all pretty straightforward, timing belt needs some special tools (£20.00) or so and is a little more intricate that a IDI engine. It's very doable tho
    1 1 0
  1. Question Audi a4 b8 1.8t 2008 160bhp general questions about the engine
    By dawid in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-01-2014, 05:35 PM
  2. Please Help MK5 Polo SDI Clutch/Gearbox replacement questions!
    By Nocturne in forum Polo - Derby - Lupo - Fox
    Last Post: 27-04-2010, 05:27 PM
  3. Question Will an SDi 2000 Polo engine fit a 2003 SDi Octavia
    By genevive in forum Polo - Derby - Lupo - Fox
    Last Post: 06-12-2009, 08:47 PM
  4. A3 cabriolet 1.9 TDI General questions regarding engine
    By PNS2007 in forum Audi A3 - Archive Topics
    Last Post: 09-09-2008, 04:24 PM
  5. General TDI maintenance
    By veedub76 in forum Golf MK4 - 1999 - 2004
    Last Post: 24-03-2008, 12:32 AM
