Thread: No turbo loss of boost PO237 code
  1. No turbo loss of boost PO237 code
    Oct 2014
    Nottingham
    Hi guys need some help here please
    I have a 1.9tdi b6 2006 passat
    lost turbo or boost just over a week ago, had vag com put into car and came up with fault code po237 which is turbo boost sensor circuit a low. I have changed the sensor and no change and just had new turbo on and still no change, I have actually put 2 sensors on and still no improvement and there is no leaks or split hoses as this has been double checked as I've just had new turbo fitted
    Any ideas or suggestions would be welcome, my guess is that something is clogged up like the egr or even the cat maybe
    Thanx
  2. Re: No turbo loss of boost PO237 code
    Oct 2014
    Nottingham
    Still had no look with this problem, I have found out that the cruise control isn't working, does the cruise control need vacuum to work?
  1. Replies: 12
    Last Post: 24-05-2017, 04:10 AM
  2. Replies: 1
    Last Post: 05-01-2013, 08:34 PM
  3. Fault code P0236 - Turbo/Super Charger Boost Sensor - what is it?
    By vipergrm in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-10-2012, 09:53 PM
  4. Question Loss of turbo........ code 17964...Help!!
    By Jakstar84 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-01-2012, 10:08 PM
  5. Please Help Limp mode loss of turbo boost
    By dan2134 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-07-2011, 03:11 PM
