Thread: auto wipers.
Results 1 to 10 of 18
  1. auto wipers.
    Jul 2014
    Salisbury
    Does anyone have issues with their auto wipers having a life of their own. Mine basically work great sometimes, but others they are really slow to come on, others they seem to come on for no reason. Heavy rain recently has made this more apparent.
    For example, I was driving the other day and the windscreen was almost opaque before the wipers decided there was enough rain to come on...yet I have them set on the most sensitive setting. Also when I start the care in heavy rain or the windscreen is covered in water the wipers do not engage until I remind them to or I start driving in a forward direction. In reverse they simply don't come on until I start travelling forward and even then it can take some time for them to engage.
    Another issue I am having is the windscreen not demisting very quickly, meaning i have to keep my wipers on to keep it cleared for quite a while.
  2. Re: auto wipers.
    Jul 2014
    Chesterfield
    16 Post(s)
    There is a very recently started thread already covering this. As recently as today it has been contributed to. You might want to ask for your query to be moved to that thread, rather than having 2 threads open on something so specific.
    But, before I go, surely you don't use your windscreen wipers to demist your screen?
    Q7, S-line, Graphite Grey, full leather, 21 inch titanium wheels
  3. Re: auto wipers.
    Jul 2014
    Salisbury
    Quote Originally Posted by Chesterfield313 View Post
    that one just seems to be a ramble about all sorts rather than anyone addressing a particular problem.
    Not to demist it on the inside which also takes an absolute age, far longer than any other car I've owned, but it keeps misting up on the outside, especially in the mornings and evenings now it's cold and damp.
  4. Re: auto wipers.
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    To be sure now, that'll probably be the cold an damp now that's causin that then?
  5. Re: auto wipers.
    Dec 2009
    Carlisle UK
    The car does need a trigger to operate the wipers, for instance, when I reverse out of my drive and then move forward 20 ft to the end of the road, the wipers do not operate unless I pull on the stalk. I also switch on rear demist and forward demist at the same time, then once on the main drag I switch back to auto a/c. Everything works as normal after this. 2.0 TDI manual.
    Last edited by daycartes; 17-11-2014 at 09:09 AM. Reason: auto correct wrongly correcting
  6. Re: auto wipers.
    Apr 2009
    Surrey
    183 Post(s)
    99% of the time I would say mine operate as planned. When the car is stationary they do reduce wipe frequency, in the same way as they would switch to intermittent if you had selected slow continuous operation, and it takes forward motion for the car to reactivate the system. Have you (or someone else ) treated the windscreen with something like Rain-X, if this is used and it goes over the sensor it can affect the system because the sensor will see less water because it is being dispersed. As to mist, the A6 is no better or worse than any other car I drive and I simply have to manually activate the wipers to clear it until the screen warms up. Such a shame that Ford's initial deal with Pilkington for the Hot Screen meant other manufacturers were unable to adopt the technology.
  7. Re: auto wipers.
    Apr 2013
    Solihull, Great Britain
    Auto wipers are certainly not as good on some days as on others. It could just be that the area in front of the sensor sometimes gets a bit more rain than the area in front of the driver, and sometimes a bit less. But when I drove lower-spec cars with a simple timer controlling the delay wipe, they were far more consistent and reliable, and seemed to need the same amount of juggling to match the delay to the amount of rain.
    And I really, really miss the Ford heated front screen at this time of year. Renaults have an electric heating element in the blower, surely it's about time Audi did something like this? It's amusing that Audi can offer you a radar to warn of vehicles in your blind spot (where others just fit a door mirror with an angled part to eliminate the blind spot) but they can't do anything about frozen windscreens!
    12-plate Audi A3 Black Edition 2.0 TFSi S-tronic Sportback in Ice Silver with DVD Sat Nav, Bose sound system, xenon headlights, Bluetooth, voice control, heated full leather seats, full electric driver's seat adjustment, privacy glass, heated auto dimming power-folding mirrors, titanium grey Rotor-style alloys, auto lights & wipers, and tyre pressure monitoring.
  8. Re: auto wipers.
    Feb 2013
    Gloucester
    57 Post(s)
    I have just bought and fitted a large dehumidifier bag for the car. It's basically like a bag of silica gel you get with new shoes etc but designed for a car. It absorbs the moisture and tells you when it's full, you then microwave it and it's good to go again. Been in for nearly a week now and there is substantially less condensation in the mornings.
    1 1 0
  9. Re: auto wipers.
    Southern County Softy
    20 Post(s)
    Quote Originally Posted by M1tchy View Post
    Gotta link...
    A4 2.5 tdi QS (mapped)
  10. Re: auto wipers.
    Aberdeen
    63 Post(s)
    Quote Originally Posted by Kar Krazy View Post
    Audi have the heated windscreen as an option on the A8. They should really offer it across the range. May not be compatible with HUD but at least you would have a choice.
  1. Auto wipers question
    By craig-v5-20v in forum Toledo
    Last Post: 06-11-2014, 11:15 AM
  2. B8 auto wipers!
    By S.line in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 17-02-2012, 01:10 AM
  3. Auto-Dim Mirror/Auto Lights/Auto Wipers Retrofit
    By mercedeslimos in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 04-07-2011, 03:50 PM
  4. Auto-wipers
    By JohnH in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-01-2008, 08:10 AM
  5. Auto Wipers???
    By mellie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-12-2007, 11:35 PM
