Thread: Fusebox power supply fuse?
  1. Fusebox power supply fuse?
    Nov 2014
    BasVegas
    Have just done a major faux-pas while installing my heated seats.
    I removed the fusebox and accidentally touched the fat black/yellow main supply cable to earth!
    There's now no power to the fusebox. Does anyone know if this has its own fuse and where it is?
  2. Re: Fusebox power supply fuse?
    May 2007
    17 Post(s)
    It'll be one of the main fuses right at the battery that will have popped. You'll probably need to get one from the dealer though. It'll be something like 100-150Amp strip fuse.
    Jim.
  3. Re: Fusebox power supply fuse?
    Nov 2014
    BasVegas
    Cheers Jim, there is a big fuse next to the battery but its ok.
    Power to the fuse box seems to come from relay 53. Have pulled the relay and it works fine but when I turn the ignition on it doesn't click over...
    I don't have access to a wiring diagram so am completely stuck
  4. Re: Fusebox power supply fuse?
    May 2007
    17 Post(s)
    The fusebox is supplied from relay No.2 in the diagram. The power leaves the relay carrier via terminal 75X below relay 1. Is that the location of relay 53?
    2 0 0
  5. Re: Fusebox power supply fuse?
    Nov 2014
    BasVegas
    Ah ok, relay 53 is location 1 above - I presumed this switched 75x due to its proximity. I'll check relay 2 now, thanks for that info
  6. Re: Fusebox power supply fuse?
    Nov 2014
    BasVegas
    Quote Originally Posted by Flash2 View Post
    Relay 2 was clicking but contacts burnt out and not making contact. Will get a new one from Audi. Thanks Flash2 without your info I would not have sourced the problem!
  7. Re: Fusebox power supply fuse?
    May 2007
    17 Post(s)
    Quote Originally Posted by Chawkster View Post
    Well done in finding the fault. I'm glad I was able to help to help you out.
    Regards.
    Jim.
  1. A6 power supply in rear?
    By SwissBuster in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 14-10-2013, 04:16 PM
  2. Power supply in boot
    By gblades in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 07-07-2011, 08:14 PM
  3. Where is the boot power supply located
    By pgarner in forum Bora - 1998 - 2005
    Last Post: 17-09-2010, 01:52 PM
  4. How To Power supply for Sat Nav in T4
    By vwbadger in forum The Commercial Range
    Last Post: 12-09-2010, 08:08 PM
  5. 04 plate t5 onboard power supply
    By MARK68 in forum The Commercial Range
    Last Post: 13-08-2010, 03:53 PM
