Thread: Workshop emissions warning and yellow warning light
  1. Workshop emissions warning and yellow warning light
    Apr 2014
    Lewes, Gb
    Golf 1.6 with the above lights now on and fuel consumption high. Is it likely to be the Lamda sensor and if so are they easy to fit?
  2. Re: Workshop emissions warning and yellow warning light
    May 2007
    17 Post(s)
    There are a number of things that could cause the emissions message, but it's unlikely to be a lambda sensor.
    If your fuel consumption has gone high, it could be a faulty coolant temp sensor. You'd really need to get it connected to a diagnostic scan tool to see what it is the engine computer is getting upset about. Until you can give us a trouble code we would just be guessing what the fault is.
    There are a few members of the forum with diag equipment that would be willing to read the codes on your car (for some beer money).
    See if anyone is in your area by taking a look at the map here : https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
    Regards.
    Jim.
    1 2 0
  3. Re: Workshop emissions warning and yellow warning light
    Apr 2014
    Lewes, Gb
    Thanks. The light has gone out now of course! I have a spare temp sensor so will put that in if it comes back on, and take it to the local garage if that doesn't do the trick. All the people on the list live quite a long way away.
  4. Re: Workshop emissions warning and yellow warning light
    May 2007
    17 Post(s)
    Just to let you know that for emissions related faults, you can get a code reader for less than £20 that will read the fault codes causing you emissions message. Spend a little more and you will be able to view data from the engine sensors too. These are generic tools that work with any modern car. Sometimes the freeze frame function of generic OBD is more useful for finding an engine fault than the dealer level diag tool. For all they cost these days, it might be worth keeping one in your tool kit.
    Jim.
  5. Re: Workshop emissions warning and yellow warning light
    Apr 2014
    Lewes, Gb
    Quote Originally Posted by Flash2 View Post
    Jim.
    thanks for the tip - any particularly good brands?
  6. Re: Workshop emissions warning and yellow warning light
    May 2007
    17 Post(s)
    Quote Originally Posted by Lewes96 View Post
    Sorry, I don't know. My unit is Bosch, but costs a bit more than £20.
    You could post the question here though : Vehicle Diagnostics Equipment- Except VCDS and I'm sure someone will be able to advise you.
  7. Re: Workshop emissions warning and yellow warning light
    Apr 2014
    Lewes, Gb
    Thanks for the tip
  1. Please Help Warning "Emissions Workshop" - EM light on ---air intake regulator flap / moter
    By wdroberts in forum Golf MK5 - 2004 - 2009
    Last Post: 30-11-2016, 10:06 PM
  2. Emissions Workshop warning light.
    By phil7132 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-08-2011, 06:31 PM
  3. Please Help Engine Warning Light & Emissions Workshop
    By stevem61 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 29-03-2010, 04:33 PM
  4. Emissions workshop - warning light
    By PeterB in forum Passat - B5 Forum - 1997 -2005
    Last Post: 02-11-2007, 02:41 PM
  5. EML warning light - EMISSIONS WORKSHOP....headache and pain!!!!
    By ggttdi in forum Golf MK4 - 1999 - 2004
    Last Post: 17-09-2007, 11:39 AM
