Thread: A4 Avant wheel bearing/CV life expectancy
  1. A4 Avant wheel bearing/CV life expectancy
    Sep 2007
    Scotland
    Morning all.
    My car is in for a service today anyway, so I've asked them to look at this.
    But over the last couple of days, I've had what I can only describe as a noisy bearing at motor way speeds. Not engine related as it only changes with road speed.
    Car has only done 31,000 miles on a 62 plate, I was thinking that this was a bit soon for a failure.
    Anyone experienced similar?
    Cheers.
    BMW 530d Sport 3.0 TDi 192PS
    Passat SE 2.0 TDi 140PS PD
    Passat CC GT 2.0 TDi 170PS CR
    Audi A4 Avant Black Edition 143
  2. Re: A4 Avant wheel bearing/CV life expectancy
    Jun 2012
    Yeovil, UK
    I had a similar sound at 50,000, which was cured by replacing a front wheel bearing.
    Not very impressive!
  3. Re: A4 Avant wheel bearing/CV life expectancy
    Pembrokeshire
    22 Post(s)
    some wheel bearings go for 300,000 miles, like the ones on my 80, but that was back in the 90's when proper ones were fitted. cheaper ones are used nowadays, some last a long time, some fail at an earlier age. thats life.
  4. Re: A4 Avant wheel bearing/CV life expectancy
    Scotland
    I've a front go at 130K, the other front at 160K and the first rear just replaced at 175K. I blame the 18" alloys and skinny tyres.
    Bad news about the fronts is that it's the whole hub assembly that has to be replaced (££££), the rears as still a bearing cartridge type.
    Pete
    2017 A4 B9 2.0 TFSi S-line S-tronic
    2009 A4 B8 2.0TDi SE Avant (written off by a van )
    2005 A4 B7 2.0TDi SE Avant (gone)
    2002 A4 B6 1.8T Sport Quattro Avant (gone)
    1995 A4 B5 2.6 Sport Quattro (gone)
  5. Re: A4 Avant wheel bearing/CV life expectancy
    Sep 2007
    Scotland
    Confirmed by Ayr Audi this afternoon, O/S/F wheel bearing shot.
    replaced under warranty.
    Car is in overnight until it can be fitted tomorrow.
    I have an A1 2.0 TDi courtesy car. Talk about pocket rocket.
  6. Re: A4 Avant wheel bearing/CV life expectancy
    Sep 2008
    6 Post(s)
    As long as new bearings are either FAG or SKF, then you should be good for 100k after replacement. Plus, fitting them properly is crucial. I had a rear wheel bearing nipped during fitting. Lasted a month before symptoms materialised again.
    2016 BMW i3 REx (80k)
  1. A4 Avant s-line 2008 wheel bearing problems
    By ferroequine in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 26-06-2013, 06:21 PM
  2. How To Change wheel bearing rear wheel
    By thecableguy12 in forum Golf MK3 - 1993 - 1999
    Last Post: 20-11-2009, 01:56 PM
  3. Question Wheel bearing noise not a Wheel bearing
    By PCDoctor in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-10-2009, 10:31 PM
  4. Multitronic Life Expectancy
    By shabazmo in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 15-03-2008, 05:22 PM
  5. Replies: 3
    Last Post: 07-07-2007, 04:25 PM
