Thread: Vw polo ignition
Results 1 to 10 of 10
  1. Vw polo ignition
    Nov 2014
    Can anybody help i put my key in ignition turn key no ignition lights on dash turns over cuts out all other things work central locking headlights stereo just no lights on ignition any ideas please
  2. Re: Vw polo ignition
    Aug 2011
    Meath
    Start with the fuses
  3. Re: Vw polo ignition
    Nov 2014
    Checked all fuses cant think of anything else
  4. Re: Vw polo ignition
    Aug 2011
    Meath
    I'd get a diagnostic scan done. What year is the car? Engine?
  5. Re: Vw polo ignition
    Nov 2014
    Tdi 02 polo
  6. Re: Vw polo ignition
    Nov 2014
  7. Re: Vw polo ignition
    Aug 2011
    Meath
    I can only suggest getting a diagnostic scan check on this map for a site member with VCDS diagnostic tool https://www.google.com/maps/d/viewer...8.kMTwqF0PoXwc
  8. Re: Vw polo ignition
    Nov 2014
    Thanks for help mate
  9. Re: Vw polo ignition
    Pembrokeshire
    22 Post(s)
    you say it turns over and cuts out ? if it starts and runs for 1 second, then stops, which is what i think you are saying, then thats the immobiliser stopping it from running. this is part of the dash cluster, so ties in with the dash not lighting up. i suspect there is either, as doc suggests, a blown fuse to the dash panel, or the dash itself has died, or there is another reason for it not powering up. to see which it is, i would start with a scan, and if nothing is conclusive from that, i would remove the dash and use a multimeter to check the power cable that should be 12v with ign on, and the earths. if you have power where there should be power, and earths where there should be earths, then i would box up the dash and send it to bba reman (google them) and get it tested and /or repaired. DO NOT even consider a used dash as it would need programming to make it work. the only real other option would be a new one from vw.
    1 1 0
  10. Re: Vw polo ignition
    Nov 2014
    Yes that is exactly what is happening i will check again tomoz thanks very much.
  1. Polo ignition problem
    By mahutchinson in forum Polo - Derby - Lupo - Fox
    Last Post: 02-09-2009, 09:52 PM
  2. Ignition wiring for 96 Polo
    By farmamick in forum Polo - Derby - Lupo - Fox
    Last Post: 30-01-2009, 01:03 PM
  3. Polo Ignition Timing
    By polo-sib in forum Polo - Derby - Lupo - Fox
    Last Post: 05-02-2008, 09:35 PM
  4. VW Polo Ignition Barrel
    By Paulaviki in forum Polo - Derby - Lupo - Fox
    Last Post: 10-09-2007, 08:36 PM
  5. ignition problem?, 1.9 tdi polo
    By polonewb in forum Polo - Derby - Lupo - Fox
    Last Post: 25-04-2007, 06:04 PM
