Thread: Help needed ,Remote and key won't open doors, I am locked out
Results 1 to 9 of 9
  1. Solved! Remote and key won't open doors, I am locked out
    May 2014
    Hi guys
    Mine is 2005 a6 2.7tdi quattro avant, Went to my car this morning, pressed remote to open, no turning sound,only flash, tried using key to open driver door, flash with a beep( same beep when lock the car) no turning sound, all doors inc driver door remain locked, I am completed locked out. the same with spare keys.
    anyone knows about this?
    thanks
  2. Re: Help needed ,Remote and key won't open doors, I am locked out
    46 Post(s)
    Did you try turning the key the other way as you only mentioned you turned it to the lock direction.
  3. Re: Help needed ,Remote and key won't open doors, I am locked out
    May 2014
    Quote Originally Posted by Chris View Post
    Hi Chris
    use key turn left to open, flash once.
    turn right to lock , nothing happens.
    use remote to open, flash twice,
    use remote to lock, flash once and a beep.
    no matters what I do, all doors remain locked.
    and yesterday mmi suddenly no sound playing radio & radio, tried reset and hold down volume, doesn't work
    are these related?
  4. Re: Help needed ,Remote and key won't open doors, I am locked out
    May 2014
    Quote Originally Posted by Lee82 View Post
    Hi Chris
    are these related?
    got it sorted, door opened with some knocks to the lock. batter is flat, started with jump start.
    how long does it take for a full charge?
  5. Re: Help needed ,Remote and key won't open doors, I am locked out
    Nov 2012
    Somerset UK
    Depends on the state of the battery, if charging it in situ please do it using the points under the bonnet. With a normal charger it may fully charge if left overnight...if you have the ability to do so, so that both the electrics and your car will be safe.
    If your 2005 has the original 9yr old battery in it best to get it replaced and keep the old one fully charged as a back-up.
    For some reason many owners seem to think a car battery will last forever
    I did predict a few battery fail posts as the weather got colder.
    1 1 0
  6. Re: Help needed ,Remote and key won't open doors, I am locked out
    May 2014
    Quote Originally Posted by MarkTM View Post
    Battery is only 2 years old, vcds scan shows fault code 00532 and 02244 which is sticky button on control head , it caused mmi did not shut down and left over night drained battery flat.
  7. Re: Help needed ,Remote and key won't open doors, I am locked out
    Nov 2012
    Somerset UK
    Ooeeer Missus, what have you been doing on the inside of your car!?
  8. Re: Help needed ,Remote and key won't open doors, I am locked out
    May 2014
    with a horrible 4 years old boy in car , anything may happen.
    one thing I learnt is do use manual key sometimes in case lock seized.
  9. Re: Help needed ,Remote and key won't open doors, I am locked out
    Nov 2012
    Somerset UK
    There is of course the boot?
    In truth my children whilst in car seats never sat in the front, as they'd invariably have something in their hands which made an airbag a dangerous thing. Even now older, if they want to play on a kindle/phone they're in the back.
    if he's yours you really can't complain too much since they're technically a 'self inflicted injury'...and were not in the American forces and don't get a medal for shooting ourselves in the foot
  1. Replies: 11
    Last Post: 20-05-2021, 09:21 PM
  2. Doors won't open from the outside
    By smiggy9 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-01-2020, 04:47 PM
  3. Please Help HELP! Car doors won't open with remote or by key!
    By vipergrm in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-12-2011, 09:20 PM
  4. Sometimes Doors won't unlock now remote key fob is intermittent
    By andrew_jmdata in forum Golf MK4 - 1999 - 2004
    Last Post: 30-01-2011, 08:37 PM
  5. second plip on remote to open other doors
    By arnieboy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 19-01-2011, 10:33 PM
