Thread: Which drain plug for oil change
Results 1 to 10 of 15
  1. Which drain plug for oil change
    Dec 2013
    Liverpool
    10 Post(s)
    Looking at doing a oil change on my A6 7.7 tdi Quatro (2007), there are 2 drain plugs, what are they both for?
  2. Re: Which drain plug for oil change
    Sep 2011
    Lurking over a keyboard ...
    As mine is a 2005 V6 TDi it has the bigger sump plug (yours will differ size/look) but location should be same on yours.
    Green lines oil level sensor, red circle engine oil drain plug.
  3. Re: Which drain plug for oil change
    Dec 2013
    Liverpool
    10 Post(s)
    Quote Originally Posted by gupsterg View Post
    Out of interest what is the other drain plug?
  4. Re: Which drain plug for oil change
    Sep 2011
    Are you talking further back?
  5. Re: Which drain plug for oil change
    Dec 2013
    Liverpool
    10 Post(s)
    Yes the one further back
  6. Re: Which drain plug for oil change
    Sep 2011
    Is yours auto? if so the very first one when going further back is the ATF oil drain and further back is the refill point.
  7. Re: Which drain plug for oil change
    Dec 2013
    Liverpool
    10 Post(s)
    Yes mine is Auto
  8. Re: Which drain plug for oil change
    Mar 2009
    Quote Originally Posted by peter goble View Post
    You've got the biggest Diesel engine out there(7.7)��������.
    On a more serious note it would also be a good idea to replace the sump plug alen key bolt when changing the oil.You'll notice it has a silver washer that gets squashed when tourqing the bolt up to create a seal between head of the bolt and the bottom of sump.I did my oil yesterday and changed it.It's only £2 or £3 for a new bolt and the silver washer should come with oil filter.Good luck.
  9. Re: Which drain plug for oil change
    46 Post(s)
    Get it from Audi parts, they're not dear <£5.
  10. Re: Which drain plug for oil change
    Aug 2012
    Bristol
    Can you tell me what size hex socket it needs? I have a 3.0 tdi v6.
  1. V5 oil filter drain plug
    By mikeybutch in forum Bora - 1998 - 2005
    Last Post: 30-07-2013, 09:00 PM
  2. Please Help What is best way to repair the oil drain plug thread on 58 plate 2.0 tdi a4?
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 21-10-2012, 05:54 PM
  3. Changing Oil - what plug do I pull to drain existing oil
    By jalz in forum Audi A3 - Archive Topics
    Last Post: 22-01-2009, 08:26 PM
  4. Oil drain plug
    By linners in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 12-11-2008, 11:14 PM
  5. Oil Drain Plug (or Sump) Removal Problem
    By Chromate in forum Golf MK3 - 1993 - 1999
    Last Post: 05-03-2008, 12:41 AM
