Thread: Newbie with questions -Audi A6
  1. Newbie with questions -Audi A6
    Nov 2014
    Connahs Quay wales
    Hi guys,
    Firstly im no mechanic or expert on cars, i have just bought an Audi A6 3.0tdi estate on a 05 plate, i don`t have a full service history but am concerned about the cambelt, ive spoken to two garages, one says its a cambelt and the other a timing chain, can anyone verify which it is.
    Secondly the fuel gauge doesn`t work which i have heard is common on this model, now does anyone know someone in the Northwest who can repair this reasonably.
    And the questions keep coming, do the wheels from an Audi A3 fit on the A6?
    The car drives lovely and im really pleased, i have had a couple of TT`s before and the quality of Audi cars has always impressed me, thanks in advance for any replies
  2. Re: Newbie with questions -Audi A6
    Feb 2009
    West Yorkshire
    10 Post(s)
    Quote Originally Posted by Timncfc View Post
    Hi guys,
    Only one I can help on is its a chain
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  3. Re: Newbie with questions -Audi A6
    Nov 2014
    Connahs Quay wales
    Thanks for your answer, what is the life expectancy of these chains, mine is really quiet, no rattles or noises
  4. Re: Newbie with questions -Audi A6
    Aberdeen
    63 Post(s)
    The fuel gauge fault is sometimes due to the sender in the tank.
    The A3 wheels will fit - the PCD is 5 x 112 and centre bore is 57.1mm on both but the offset on the A3 alloys will be between 45-50, slightly less on the A6. A4 will also fit. Just watch as the newer models went to a centre bore of 66.6mm which means you need spigot rings. Chain is on the car for life and very expensive if it goes wrong. Tensioners also wear out. If it is quiet, the general consensus is keep the oil changes very regular and you should (might)be ok. I did 130k in my one and had no issues and there are others with far higher mileages, other guys not so lucky.
    What spec have you got on the car?
  1. Solved Audi newbie with some questions!
    By careless_adi in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 05-07-2014, 07:36 AM
  2. Newbie questions...
    By Ripley101 in forum Passat CC
    Last Post: 07-04-2013, 03:35 AM
  3. Please Help 1.8T newbie questions
    By ste8270 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 26-09-2010, 03:54 PM
  4. More ipod questions from a Newbie Audi driver!!
    By JumpUp in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 04-04-2009, 12:17 PM
  5. Audi Coupe a few questions from a newbie..
    By Audi coupe in forum Audi Cabrio - Coupe - Quattro's - UR Quattro
    Last Post: 05-01-2008, 05:35 PM
