Thread: audi a6 c5 3.0l v6 trouble?
  1. audi a6 c5 3.0l v6 trouble?
    Oct 2013
    Redcar cleveland
    Hi, I have just recently bought my 2003 a6 avant 3.0l v6 Quattro, but am having a few problems?,
    the main one is it seems to be going through about a litre of oil in about ten days but there are no signs of any leaks and no smoke? is this normal?
    everything seems fine and pulls well although a bit heavy on fuel, any ideas welcome?
    cheers mark
    Kind Regards
    Mark.
  2. Re: audi a6 c5 3.0l v6 trouble?
    Jan 2009
    Winchester, Hampshire, U.K.
    I've just bought the exactly the same vehicle myself about a month ago, but not noticed any particular oil consumption yet. I changed the oil at the W/E so will start monitoring it. How many miles are you doing in 10 days? The Audi owners handbook states that one litre of oil per 1000Km (625miles) is acceptable.
    2003 3.0 quattro Avant
  3. Re: audi a6 c5 3.0l v6 trouble?
    Oct 2013
    Redcar cleveland
    about 150 miles, I would have thought even audi's guide is very excessive (to use 1L per 625 miles) knowing how much the oil cost? as all other cars I have owned never used any!
    Kind Regards
    Mark.
  4. Re: audi a6 c5 3.0l v6 trouble?
    Jan 2009
    Absolutely agree its excessive but that's what they say. The only sources of oil use I know of are: Leaks, worn bores/rings, worn valve guides/valve stem seals, broken ring(s). All of these except leaks will be burning it and at the rate you're talking about I would have thought you would see very blue smoke out of your exhausts. Maybe the first thing to do would be to get a compression test. A least then you'd know the bores/rings are O.K. - or not! What oil are you using?
  5. Re: audi a6 c5 3.0l v6 trouble?
    Apr 2009
    Epsom Downs
    Get someone to drive behind you and check the exhaust smoke. You can have quite a bit of smoke coming out without actually seeing it in the mirror (depending on the aerodynamics).
    If it smokes the first time you put your foot down after a long coast down hill, it's probably valve guide seals, and worth fixing.
    If it smokes all the time (generally on acceleration) it's most likely rings (or turbo if you have one) and probably worth selling...
    Allroad 2.7 TT 2004
    Jensen Interceptor III (Now sadly Sold)
    Giant full-sus Mountain bike
    Urban Mover Electric Mountainboard
    Chinese no-name electric bike
  6. Re: audi a6 c5 3.0l v6 trouble?
    Feb 2009
    West Yorkshire
    10 Post(s)
    If 1 litre per 625 miles is acceptable, 5000 miles is an oil change.
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  7. Re: audi a6 c5 3.0l v6 trouble?
    Jul 2011
    Norway
    Quote Originally Posted by A11mcr View Post
    cheers mark
    Good thing is you didn't buy a 4,2, the worst cases of them use 10 litres of oil in about one day !!
    A more serious answer is that it's also a question about wich oil is in your engine ? Instead of topping up, change th oil to something thicker
  1. Trouble starting Audi A4 since new DMF
    By A4mike in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 14-08-2014, 03:21 PM
  2. Audi A4 avant 2.5 v6 tdi trouble setting off in 1st gear and reverse
    By Transporter boy in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-09-2013, 07:53 PM
  3. Please Help 94 Audi 80 TDI 1Z Starting Trouble...
    By Bob1z in forum 80 - 90
    Last Post: 14-07-2010, 06:36 PM
  4. 1996 Audi A4 quattro trouble codes!!!
    By heptapneuma in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-12-2007, 02:16 PM
  5. Help - Audi A4 Indicator trouble
    By PeterT in forum Audi A4 - Archive Topics
    Last Post: 03-07-2007, 06:35 PM
