Thread: Trouble starting from cold and judder at idle on 1.9 PD engine
  1. Trouble starting from cold and judder at idle on 1.9 PD engine
    May 2007
    Any help would be greatly appreciated; I have a golf MKV tdi 1.9 BKC with starting issues.
    Unfortunately it is struggling to start from cold (ambient temperature 13 degrees Celsius), and I presume it is no coincidence but once started it has a significant judder on tick over. However, this is intermittent and it can have no judder. raising the revs to 1000 sees the judder disappear
    Once warm seems to start up a lot easier than when cold
    This has been becoming worse over past few weeks.
    The VAG COM throws out 2 codes
    16688 cylinder 4 p0304 misfire detected intermittent
    17057 cylinder 3 Glow Plug circuit p0673 Electrical Fault intermittent.
    However, when I clear codes and then try to start car it struggles to start and the codes are not there when I check again so I do not know if this is spurious?
    When starting the car… I need to put my foot on accelerator whilst cranking for about 10 –15 seconds (maybe twice or three times) before she starts
    The car has had in the past 6 months/ 6k miles
    New Battery
    New injector loom
    New oil and filter
    New fuel filter
    New Air filter
    New Glow plugs
    New DMF and clutch
    New Alternator clutch pulley
  2. Re: Trouble starting from cold and judder at idle on 1.9 PD engine
    132 Post(s)
    1980 Post(s)
    One of those will be the glow plug loom which is a bit of a sketch to change. The cylinder 4 code, in view of the loom having been changed, is a bit worrying.
  3. Re: Trouble starting from cold and judder at idle on 1.9 PD engine
    May 2007
    Ominous as as in injector failing?
  4. Re: Trouble starting from cold and judder at idle on 1.9 PD engine
    132 Post(s)
    1980 Post(s)
    Yes, possibly, or a worn cam/lifter. 8 valve PD injector failure is quite rare - cam lobe failure isn't........
  1. Very Cold Starting - Vibration/Judder
    By blueazman74 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-04-2013, 10:17 AM
  2. Engine fan comes on at cold start, heaters blowing cold air when idle
    By walsie in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-12-2010, 07:26 PM
  3. Trouble cold starting after new injector
    By mm707 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 22-11-2010, 03:01 PM
  4. A3 Cold Starting Trouble
    By GHanson in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 27-03-2008, 10:33 AM
  5. V6 TDI Cold starting and idle
    By Mark05 in forum Archive posts
    Last Post: 06-06-2007, 01:22 PM
