Thread: MMI not working, black screen and controls
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 47
  1. MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    Hi all,
    Unfortunately my mmi in my 2010 A6 Avant has stopped working properly.
    Its the basic with dvd nav and Bluetooth.
    When I put the key in the ignition the mmi screen doesn't come on at all. I start the car and still nothing. The controls/buttons are not illuminated either and unresponsive.
    My Bluetooth wasn't working properly yesterday but after I stopped and restarted the car it was fine. (was very crackly on my end)
    Just been out in the car and mmi is dead. However, my friend did the reset button sequence and after 10s or so the splash screen appeared and it worked fine. However, I've just been back out about 30 mins later and it's dead again.
    Not able to do vcds scan yet as my laptop battery is dead and so on charge.
    HELP!
    Thanks.
    Sent from my K00C using Tapatalk
    Audi A6 2.0 TDi S-Line Special Edition (60 Reg) Phantom Black
  2. Re: MMI not working, black screen and controls
    Jul 2011
    Near Uxbridge
    Were you using the rear washer by any chance? If so have a look for my thread entitled 'the day the music died' .
    I hope it's not the same issue as I had...
    Neil
    Sent from my HTC One using Xparent Red Tapatalk 2
    Consultation en ligne viagrasansordonnancefr.com immunite des francais
  3. Re: MMI not working, black screen and controls
    Oct 2014
    England
    Probably find something on the MOST loop has does mate, it drags everything else down with it. If your Bluetooth was actingnuo, this is the prime candidate for failing. It would appear they are prone to water ingress where they are located. You need to get a bypass loop and eliminate componants.
  4. Re: MMI not working, black screen and controls
    May 2014
    Darlington
    78 Post(s)
    From 2008 Audi changed from MMI 2G to MMI 3G and with that did away with the following hardware modules Control Head, AMI, Navigation, Bluetooth & SDS and combined them into the Audi Multimedia (5F) module, so there is no longer any module under the carpets, they also did away with the basic AMP and integrated that into the radio module.
    You need to get VCDS up and running and check for fault codes and also perform an Optical Bus diagnostic as shown here Ross-Tech: VCDS Tour: Optical Bus Diagnostics as you will get error on all of the modules on the MOST bus. If you don't have Bose then the most common module to fail on the 3G setup is the radio module, you may want to unplug the power connector and leave it for a minute or two then power it back up.
    Another question, are you getting any sound when the screen is blank as it could just be a faulty screen.
    3 0 0
  5. Re: MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    Thanks for the replies.
    No water in the boot so don't think it's that. Laptop should be charged so will try to do a scan.
    No sound through the speakers. There is a clicking noise when I put the ignition on, but don't know if this is the car or the system trying to do something.
  6. Re: MMI not working, black screen and controls
    Jul 2013
    76 Post(s)
    Check the buttons are not stuck in causing the system to have problems.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
    0 2 0
  7. Re: MMI not working, black screen and controls
    Sep 2013
    Measham, UK
    Quote Originally Posted by Owendavies View Post
    Looks like an error with the CAN Bus... whatever that means :/
    Address 19: CAN Gateway (J533) Labels: 4F0-907-468.clb
    Part No SW: 4F0 907 468 M HW: 4F0 907 468 F
    Component: GW-BEM 4CAN-M H06 0035
    Revision: LB100029 Serial number: 2900L109298020
    Coding: 000B03
    Shop #: WSC 02391 823 56573
    VCID: 397F4EE1B0C805D69C3-806C
    Subsystem 1 - Part No SW: 8K0 915 181 C HW: 8K0 915 181 C
    Component: J367-BDM H07 0125
    3 Faults Found:
    02256 - Quiescent Current
    001 - Upper Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100001
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 149
    Mileage: 117063 km
    Time Indication: 0
    Date: 2014.10.23
    Time: 10:34:00
    03041 - Energy Management Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 148
    Mileage: 117063 km
    Time Indication: 0
    Date: 2014.10.23
    Time: 13:34:00
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.20 V
    Count: 18
    00384 - Optical Databus
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 5
    Fault Frequency: 2
    Reset counter: 111
    Mileage: 117112 km
    Time Indication: 0
    Date: 2014.10.23
    Time: 22:35:45
    Freeze Frame:
    Bin. Bits: 00000
    Voltage: 12.30 V
    Count: 11
    Bin. Bits: 00000
    Can anyone suggest what I need to do next / have a look at? Has something just come loose, or has a module died on me? Havent done the BUS diagnostic you mentioned yet...
    Strangely, when I had finished the scan I pressed the Radio button a few times and it all came to life! But I fully expect it won't be there when I go back to it to go to work at 10.30am
    Thanks.
    Owen.
  8. Re: MMI not working, black screen and controls
    May 2014
    Darlington
    78 Post(s)
    Run the optical bus Diagnostic (System need to be in a fault state when you run this)
    Questions.
    Do you have bose
    Did you power down the radio module like I said in my first post.
    Can you post up the gateway installation list.
  9. Re: MMI not working, black screen and controls
    Jul 2011
    Near Uxbridge
    When mine went south I didn't see any water in the boot.. just a few drips on the elbow in the washer pipe above the MMI unit in the left cubby hole in the boot...no water anywhere else in the boot.
  10. Re: MMI not working, black screen and controls
    Apr 2012
    Aylesbury, Bucks
    8KO 915 181 C when googled comes up with "Battery Control Unit" and 4FO 907 468 F is "MMI Gateway", both relatively cheap to buy on ebay. CAN Bus is just(!) a type of communiucations network / protocol, like Ethernet, Modbus, Profibus etc. and in the case of Aud uses a fibre optic "cable" to pass data. A "gateway" is just that - a means of connecting to the network from a device - it changes the data into the correct form to be used on the CANbus.
    2018 (2017MY) S3 2.0TFSI Sportback Quattro S-Tronic in Nano Grey Metallic.
    Black Edition, Reversing camera, Parking System Plus, Hill Hold, Super Sports seats, heated, Dipping exterior mirrors, B&O, Advanced Key, Magnetic Ride, Red Calipers, 19x8J 5-V-Spoke wheels in matte titanium.
  1. Have I ruined my MMI screen?
    By AudiCraig in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-11-2013, 04:49 PM
  2. Door controls not working
    By BIGECK in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 15-10-2010, 10:08 PM
  3. help steeringwheel controls and horn not working
    By chrisb1 in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 27-06-2009, 08:38 PM
  4. CD Changer - MMI Controls
    By bluestar_ale in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-07-2008, 02:43 PM
  5. Satnav screen / moving heating controls
    By Cosmosblue in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2007, 09:45 AM
