Thread: 2001 passat radio fault
  1. 2001 passat radio fault
    Jul 2012
    lowconiscliffe
    my radio casstte has stopped lighting up since having it valleted the lcd works and it plays ok,also the outer heater vents light up but not the inner ones any ideas where too start ?
  2. Re: 2001 passat radio fault
    May 2007
    17 Post(s)
    They haven't knocked the dimmer control while they have been cleaning the car, have they? Try moving the dimmer control up and down a few times and see if they come back on.
    Jim.
  3. Re: 2001 passat radio fault
    Jul 2012
    lowconiscliffe
    Tied that no joy
  4. Re: 2001 passat radio fault
    May 2007
    17 Post(s)
    Did any of the dash lights brighten & dim when you operated the control? Does the glovebox light work? What about the number plate lights?
    If the glovebox & No. plate lights are working then it looks like the dimmer control is faulty. You could confirm that by bypassing the dimmer and see if that brings the dash lights back on.
    Jim.
  5. Re: 2001 passat radio fault
    Jul 2012
    lowconiscliffe
    Dash lights working dimmer working and glove box and number plate lights working
  6. Re: 2001 passat radio fault
    May 2007
    17 Post(s)
    OK, I give in
    I had a quick scan of the wiring diagram and all the vents are supplied power and get their earths via a common splice in the dash wiring, so there isn't any reason why the center vents wont light up when the outer ones do.
    The radio illumination is supplied from a separate splice and the earth for those bulbs must be OK because the radio is working. Basically, according to the diagram, there isn't anything common to the illumination that isn't working that isn't also connected to the things that are.
    I'd remove the radio and check the illumination supply wire (grey/blue) and see if it has 12V on it (side lights on & dimmer on full bright).
    Jim.
  7. Re: 2001 passat radio fault
    Jul 2012
    lowconiscliffe
    thanks flash
  1. 2001 - (Y) 100BHP Passat Below Full Power Fault - Diagnosis Help Please!
    By rjsdavis in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-02-2010, 08:39 PM
  2. 2001 Passat CD Interchanger fault
    By Timbo in forum In Car Entertainment
    Last Post: 23-02-2009, 02:52 PM
  3. 2001 Passat TDi 130 Engine running fault nightmare
    By Passatnightmare in forum Chat - Anything with wheels
    Last Post: 05-08-2008, 08:48 PM
  4. passat 2.0se 2001 fault code
    By mendit in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2008, 10:55 PM
  5. Radio Reception 2001 A4 2.0 SE
    By dodger2402 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-02-2007, 06:18 PM
