Thread: B6 Passat 2006 1.9 BXE P0401 code?
  1. B6 Passat 2006 1.9 BXE P0401 code?
    Aug 2012
    Keighley
    Hi guys,
    I've had a reoccurring fault code that keeps coming back after 20 miles. P0401 which says egr insufficient flow. I've removed the EGR valve to see if it was stuck, it was partially gunked up but I've seen worse. I cleaned it any how and cleared the code. It's back
    I've checked the vacuum pipe from the valve to the main vacuum block and no splits. I've heard it could be the MAF, the cooler, the valve itself and I've even heard someone mention the turbo. I have vcds so if anyone requires any readings to help me out I would be very grateful.
    Thanks.
  2. Re: B6 Passat 2006 1.9 BXE P0401 code?
    Aug 2011
    Meath
  3. Re: B6 Passat 2006 1.9 BXE P0401 code?
    Nov 2012
    Somerset UK
    I had a similar issue on my Audi A6 3.0
    001025 - EGR System
    P0401 - 002 - Insufficient Flow - Intermittent
    Freeze Frame:
    Fault Status: 00110010
    Fault Priority: 0
    Fault Frequency: 2
    Reset counter: 255
    Mileage: 168910 km
    Time Indication: 0
    Date: 2014.09.25
    Time: 12:51:15
    In my case it was the cast ali pipe between the TB and intake manifold, off that pipe are two nostrils that lead to the EGR, removed and used oven cleaner from 99p shop and a power washer. Dried and replaced and no return of the issue.
    Good luck!
  4. Re: B6 Passat 2006 1.9 BXE P0401 code?
    Aug 2012
    Keighley
    I've done all that. Still no cigar.
  5. Re: B6 Passat 2006 1.9 BXE P0401 code?
    Aug 2012
    Keighley
    Thanks Mark, I'm hoping to get some parameters so I can narrow down any dicky readings.
  6. Re: B6 Passat 2006 1.9 BXE P0401 code?
    Nov 2012
    Somerset UK
    pics can be seen here
    TB Cleaning Photos
    Basically crud accumulates around anywhere near & in the EGR you just have to clean it all out
  1. Please Help Touran 2006 BXE clutch problems
    By xouser8334 in forum Touran - Sharan - Caravelle
    Last Post: 24-10-2016, 06:49 AM
  2. Error code P0401
    By cabledeck in forum Golf MK6 - 2009 - 2013
    Last Post: 18-08-2013, 08:35 PM
  3. Golf MK5 1.9TDI Fault Code P0299 +P0401
    By browser1 in forum Golf MK5 - 2004 - 2009
    Last Post: 14-11-2010, 04:35 PM
  4. VW Golf P0401 EGR problem
    By PURCELM2 in forum Golf MK4 - 1999 - 2004
    Last Post: 17-04-2008, 01:17 PM
  5. bora fault p0401
    By DONNELLAN600 in forum Golf MK4 - 1999 - 2004
    Last Post: 10-04-2008, 06:23 PM
