Thread: Emissions workshop, EML and limp mode - MK4 TDI 130
  1. Emissions workshop, EML and limp mode - MK4 TDI 130
    Aug 2013
    Felixstowe
    Hi guys,
    I have a MK4 Golf GT TDI 130. Recently the Emissions workshop warning has come up and thrown up the EML. It is a strange issue, sometimes it stays on for a few days, sometimes it goes away when driving and it's hit and miss whether it stays on when i start the car after having left it overnight or at work etc.
    It keeps throwing the car into limp mode, but not all the time. When the warning first comes on the car is in limp mode, but as soon as the car is turned off and on again (even if the warning and EML stay on) it is back to driving normally. Driving it at speed (over 70mph) seems to make it go back into limp mode, but below that even if thrashed somewhat it doesn't seem to go back into it.
    I have tried plugging it in to a scanner and vagcom, but for some reason it doesn't seem to be storing any codes. As soon as i plug vagcom in even if the light is on when i use it, it says there are no fault codes. I hit clear anyway and the light will be gone.
    I've tried looking at different measuring blocks - nothing seems particularly off. No stuck readings, wildly fluctuating ones etc. although i only really looked at idle and didn't do a proper log.
    Any suggestions? I have replaced the coolant temp sensor already.
  2. Re: Emissions workshop, EML and limp mode - MK4 TDI 130
    Jul 2007
    did you use a genuine vag coolant temp sensor?
  1. 03 GT TDI 130 - Limp Mode.
    By Stueyboy1989 in forum VCDS - Help Requests
    Last Post: 16-03-2009, 10:07 AM
  2. golf Mk4 GT TDI 130 air leak / limp mode
    By leemasiuk in forum Golf MK4 - 1999 - 2004
    Last Post: 11-01-2008, 05:26 PM
  3. tdi 130 lack of power and limp mode !!
    By BICCUS1 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 08-10-2007, 08:05 PM
  4. EML warning light - EMISSIONS WORKSHOP....headache and pain!!!!
    By ggttdi in forum Golf MK4 - 1999 - 2004
    Last Post: 17-09-2007, 11:39 AM
  5. 2002 Golf TDI 130, limp Mode, please help
    By wasabi in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 22-05-2007, 11:04 AM
