Thread: Heated rear window not working - mk 4 gt tdi.
Results 1 to 10 of 17
  1. Heated rear window not working - mk 4 gt tdi.
    Jan 2011
    Birmingham uk
    Hi, I need some help as my heated rear window has suddenly stopped working on my golf gt tdi mk4. I have checked the fuse 25a and its fine,any ideas maybe the switch? Is there a relay for this? I have very limited knowledge on mechanics so any help is appreciated.Cheers.
  2. Re: Heated rear window not working - mk 4 gt tdi.
    Feb 2013
    Gloucester
    57 Post(s)
    Have a look on the elements in the rear window and look for any damage, they are really thin and fragile so if you have knocked them while loading/unloading you may have damaged them, likewise if you have had any stickers etc on there you may have damaged it as well.
    If you can't see anything try a multimeter across the elements to ensure you have a voltage registering.
    If you find some damage you can buy a repair kit which is like a metallic paint you just paint over the damaged area to give the circuit continuity again.
  3. Re: Heated rear window not working - mk 4 gt tdi.
    Jan 2011
    Birmingham uk
    Quote Originally Posted by M1tchy View Post
    Thanks for your reply.I was thinking it could be the element damaged and was thinking I would have to replace the whole screen.
  4. Re: Heated rear window not working - mk 4 gt tdi.
    Feb 2013
    Gloucester
    57 Post(s)
    No problem. Something like this will do.... Halfords | Granville Rear Heater Repair
    And a how to..,.
    How to Repair a Rear Defroster : Applying Defroster Repair Compound - YouTube
  5. Re: Heated rear window not working - mk 4 gt tdi.
    May 2007
    17 Post(s)
    If it was element damage only the damaged elements wouldn't demist. It's unlikely the whole screen would be effected.
    But as Mitchy says, the first thing to do would be a voltage test, just because it's easy to do.
    Just gently touch your voltmeter probes onto the ends of each element on the inside of the screen. You should get about 14Volts on each one.
    Do the test with the engine running. The rear screen heater doesn't work if the alternator isn't charging.
    Jim.
  6. Re: Heated rear window not working - mk 4 gt tdi.
    Jan 2011
    Birmingham uk
    Thanks for being helpful but someone advised me today it could be a relay so will check that first.
  7. Re: Heated rear window not working - mk 4 gt tdi.
    Jan 2011
    Birmingham uk
    Hi Jim,thanks for your reply.I will try what you suggested but gonna check to see if its a dodgy relay first.
  8. Re: Heated rear window not working - mk 4 gt tdi.
    May 2007
    17 Post(s)
    Quote Originally Posted by dizzymac View Post
    It's been a while since I've worked on a Mk4, so I checked to be sure and there doesn't appear to be a relay in the HRW circuit.
    Can you hear a relay clicking when you switch it on? If not, did you in the past when it was working?
    Let us know what you find.
    Jim.
  9. Re: Heated rear window not working - mk 4 gt tdi.
    Jan 2011
    Birmingham uk
    I think your indeed right,I checked and it stated there was no relay in a diesel There hasn't been any clicking noises when switching on. I'm gonna check the wiring in the tailgate shortly so will let you know.
  10. Re: Heated rear window not working - mk 4 gt tdi.
    May 2007
    17 Post(s)
    Check for broken wires in the rubber tubing where the wiring loom enters the tailgate on the passenger side near the tailgate hinge.
  1. Heated rear window & air con not working
    By Steadyaway in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-11-2010, 03:53 PM
  2. Please Help Heated rear window only half working
    By Big Harry in forum New Member Introductions
    Last Post: 31-10-2009, 01:27 PM
  3. T4 fog light and heated rear window not working
    By RichardT4 in forum The Commercial Range
    Last Post: 28-10-2009, 10:59 AM
  4. A4 avant heated rear window not working
    By adl in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 16-10-2009, 03:15 PM
  5. Replies: 1
    Last Post: 20-07-2008, 09:36 PM
