Thread: Error Code P242A.?
Results 1 to 10 of 11
  1. Error Code P242A.?
    Mar 2014
    Nottingham. UK
    Hello folks,
    ive had my glowplug (curly worm) light on for a while now and have only just managed to get it read.
    The error code is coming up as, " 4911 - P242a, Exhaust Gas Sensor Circuit Bank 1 Sensor 3 ".
    my question is,
    1, where is this sensor located?.
    2, if possible does anybody have the part number for this sensor?.
    3, should this sensor not be mapped off when a dpf delete is carried out.?.
    Vehicle: 2011 A6 2L tdi s-line 170 cr.
  2. Re: Error Code P242A.?
    Jan 2013
    Wessex. and Southern France
    114 Post(s)
    Just out of interest, how did you get on at mot time with DPF delete?
  3. Re: Error Code P242A.?
    Nov 2012
    Somerset UK
    I googled the fault code you've posted and it says that the sensor in question 'may prevent your DPF from completing a regen cycle'...so if you've had a delete it should, by all logic, have been mapped out
    Was you scan via VCDS?
  4. Re: Error Code P242A.?
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by Whippy53 View Post
    Passed, because the dpf body hasn't been removed, it was cut open and gutted and welded back together. So to look at it, it looks like its still there.
    (2011 A6 2.0 TDI S-LINE 170Ps CAHA)
  5. Re: Error Code P242A.?
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by MarkTM View Post
    I took it to a local mechanic and he found the error code via his snap-on device.
  6. Re: Error Code P242A.?
    Jul 2013
    76 Post(s)
    This is the temperature sensor G495.
    its the first sensor on the DPF body from the turbo side look at ssp 420 page 53.
    Don't get it confused with the Lambda sensor on the CAT.
    Dan
    2017 Q5 S LINE QUATTRO 190 BHP
  7. Re: Error Code P242A.?
    Mar 2014
    Nottingham. UK
    Quote Originally Posted by dan2485 View Post
    Don't get is confused with the Lambda sensor on the CAT.
    Thanks. And what is SSP.?
  8. Re: Error Code P242A.?
    Jul 2013
    76 Post(s)
    Google Audi SSP 420.
    Its the audi self study programme for the 2.0 L common rail engine.
    You most likely need to replace the sensor with a Squib to fake the reading so that error stop generating.
    Dan
  9. Re: Error Code P242A.?
    Nov 2012
    Somerset UK
    May I ask what your Basic Emissions Test (BET) results were with no Cat?
  10. Re: Error Code P242A.?
    Oct 2015
    Birmingham
    I thought I'd add to this rather than start a new post.
    Where is this sensor located on the passat b6? I've got the same error and same sensor.
    Is there a part number you may have?
  1. Error code
    By magic123 in forum VCDS - General Questions
    Last Post: 13-07-2014, 05:02 PM
  2. Replies: 0
    Last Post: 09-07-2009, 03:35 PM
  3. Replies: 0
    Last Post: 09-07-2009, 03:03 PM
  4. Help with error code
    By fabijaz in forum VCDS - Help Requests
    Last Post: 16-01-2009, 11:55 AM
  5. Error code help
    By dysonco in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2008, 12:34 AM
