Thread: Newly purchased Crafter - problem :(
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 46
  1. Re: Newly purchased Crafter - problem :(
    Oct 2005
    All modern VAG OBD ports are 16 pin but there are a few different cables/leads though.
    Keeping it as simple as possible;
    HEX-COM is the older cable which won't work with CANBUS equipped vehicles (neither will VCDS Lite). I purchased one of these in early 2005.
    HEX-USB+CAN is the modern version of the above cable which will work with CANBUS equipped vehicles.
    If you have the lead to hand, check the sticker on it, it should tell you everything you need to know - post a photo if you're not sure though.
    1 1 0
  2. Re: Newly purchased Crafter - problem :(
    Oct 2014
    Leeds, West Yorkshire
    Quote Originally Posted by gupsterg View Post
    Post the DTCs (fault codes) and perhaps then someone can give better answer, without them bit of a guessing game.
    As a 2010 plate it must be a 2.5 TDi?
    Will do
    Yes its the 2.5 tdi
  3. Re: Newly purchased Crafter - problem :(
    Oct 2014
    Ah ok, now im thinking i have hex+com
    Suppose all i can do is give it a go. Is there a section on the forum to find out who and where members have the ability to scan?
  4. Re: Newly purchased Crafter - problem :(
    Sep 2011
    Lurking over a keyboard ...
    Recently I installed Link:- Beta 14 if memory serve me correct some of the labels for things shown in VCDS for the crafter were better and also it includes a firmware update to the VCDS HEX-CAN cable which may not make difference in use but every little helps!
    Quote Originally Posted by Super_fish View Post
    Ah ok, now im not sure. Mine is USB to 16 pin - which i assumed was the hex+can. As opposed to serial port to 16 pin.
    Does it look like this Link:- http://www.ross-tech.com/vag-com/hex-usb+can.html
  5. Re: Newly purchased Crafter - problem :(
    Oct 2014
    Looks like that, bar the colour (its a ebay jobbie) and no label
  6. Re: Newly purchased Crafter - problem :(
    Sep 2011
    Is it a genuine cable brought from ebay seller? if so updated software and firmware will work.
    If non genuine cable brought from ebay seller? very little chance of software/firmware update working as it will detect it is non genuine.
  7. Re: Newly purchased Crafter - problem :(
    #17
    Oct 2014
    Yeah non-genuine. May have to purchase the real deal. But if anyone has teh genuine cable close ish to Leeds and would be willing to scan the van for some beer tokens id be willing to come to them.
  8. Re: Newly purchased Crafter - problem :(
    #18
    Mar 2008
    Just Cumbria now.
    There certainly is. VCDS - Users Locations
    Nothing to see here, move along..
  9. Re: Newly purchased Crafter - problem :(
    #19
    Oct 2014
    Quote Originally Posted by Hex69 View Post
    Yup found that. Thank you
  10. Re: Newly purchased Crafter - problem :(
    #20
    Oct 2014
    Ok, update. Thankfully the father in law has a Hex+Can cable... not sure its genuine, but it looks exactly like the one on the Rosstech site, but doesnt say Rosstech on it. Problem is when ive installed vdcs 12.12.3 and tried connecting it to the van it cant find a port regardless of which USB port i put the cable in.
    EDIT - ok, it cant be genuine. As it would have recognised it.
  1. Newly Purchased 2005 A4 B7 2.0D S-Line
    By IrishLad in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 08-05-2014, 03:28 PM
  2. Crafter van intermittent ignition problem
    By Damian147 in forum The Commercial Range
    Last Post: 30-04-2013, 07:36 PM
  3. Vw Crafter High tickover problem!!!!!
    By eezygeezer in forum The Commercial Range
    Last Post: 22-08-2011, 09:38 PM
  4. Engine Fan Problem - Crafter
    By MortLogistics in forum The Commercial Range
    Last Post: 15-04-2010, 02:55 PM
  5. Just purchased an A3 - gear box problem? help?
    By KuTz in forum Audi A3 - Archive Topics
    Last Post: 26-09-2008, 11:27 PM
