Thread: Planning to buy A6 S-line 2009-2010 2.0TDI
Results 11 to 20 of 27
  1. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #11
    Nov 2012
    Somerset UK
    Quote Originally Posted by hufodorp View Post
    I have noticed one issue though. The rear windows were closing perfectly while I had the windows a little bit wet. Now when they are dry, both rear windows are running out of the side rail/beed while they are closing. The windows are tilting a little bit horizontally. If I help them keeping in the side rubber/beed they are closing fine. What is the cure for them?
    Have never heard or read of this before on the forum, I would suspect that having covered 26k+ miles per annum it was a reps car and that the rear windows may never have been used before?
    Naturally the person you bought it from was probably aware
  2. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #12
    Oct 2014
    Dublin Ireland
    Quote Originally Posted by MarkTM View Post
    I have figured it out what have caused it. Today it was all fine so I did not get why were the windows doing that on the back. I have realized that the car wasn't in level when it happened. My drive way to the house is steep enough and the car was nose pitch up on the drive way. This way the windows are tilting backwards when they are closing and causing this to happen. If the car is in level or nose pitch down everything is fine. It is a really strange thing but I'm glad that I don't need to take the door cards off to fix it.
    Does anybody suggest a cheap source for a VAG-COM set which would be compatible with C6 series 2010?
  3. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #13
    Feb 2009
    West Yorkshire
    10 Post(s)
    Vag com or VCDS as it is known available from 'NHN' on this forum
    NOW GONE 2007 A6 2.7TDi Avant Le Mans Edition (180)
    Mods:- ECU Remap, Rear Air Suspension, Rear Led Lights, Rear View Camera, Rear Privacy Glass, Titanium wheels, Colour Coded Fog Light Surrounds, FBMFSW, AMI, DAB, Chrome S6 pedals, Front Grille De-chrome, window surround de-chrome.
  4. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #14
    mostly in the garage
    Of course you could just leave the windows shut and not use them but it's not difficult to remove the door trim and if necessary the complete window frame to investigate why the glass is loose. Provided you have somewhere to work under cover that is.
  5. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #15
    Oct 2014
    Dublin Ireland
    Quote Originally Posted by Lukenkarl View Post
    Thanks for the tip. I will send him a PM.
  6. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #16
    Oct 2014
    Dublin Ireland
    Quote Originally Posted by c4a5er View Post
    I think I will leave it like that as it is fine as long as the car is not on steep uphill position. Although I would be curious if somebody would check to see if it is happening with another car as well?!
  7. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #17
    Definitely not a problem on the A6 I owned...
  8. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #18
    Oct 2014
    Dublin Ireland
    Well! I might have a look if it is still doing it, although I'm a little bit surprised that both sides are doing it.
  9. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #19
    Feb 2009
    West Yorkshire
    10 Post(s)
    Seems a common thing
    Rear window issue on facelift model...
  10. Re: Planning to buy A6 S-line 2009-2010 2.0TDI
    #20
    Nov 2012
    Somerset UK
    Erm Luke, it's the same poster on both.
    Pay attention man!!
    0 3 0
  1. Solved 2010 A6 2.0tdi 170 S-Line diy service. Questions
    By XsApollo in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 31-05-2014, 10:20 AM
  2. 2010 A6 2.0TDI S Line Multitronic Limited Edition woes
    By AudiW in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-03-2013, 05:53 PM
  3. C6 2.0tdi s line 170 2009 Headlights
    By nigedvd in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 06-06-2012, 12:43 AM
  4. Please Help a4 s line diesel manual 2010 plate fan staying on !! / a4 s line special addition spec ??
    By garry5510 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 05-02-2012, 06:36 PM
  5. 2009 - 2010 subtle differences
    By Jop in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-08-2009, 10:18 PM
