Thread: What is best 2.0 tdi engine
Results 1 to 9 of 9
  1. What is best 2.0 tdi engine
    Jul 2014
    donegal
    Can anyone say what is best engine code to have in 2.0tdi
  2. Re: What is best 2.0 tdi engine
    london/ UK
    go for the CR engine from 2008 onwards, it's not bullet proof but much more reliable compared with the longitudinal PD engine...
  3. Re: What is best 2.0 tdi engine
    Sep 2011
    Lurking over a keyboard ...
    Which would mean you'd want an A4 B8/8K as the common rail engine is not available in the A4 B7/8E.
  4. Re: What is best 2.0 tdi engine
    Pembrokeshire
    22 Post(s)
    best 2.0 is a 1.9
    1 1 0
  5. Re: What is best 2.0 tdi engine
    Jul 2014
    donegal
    Would any thing need to be moddified to make cr engine fit
  6. Re: What is best 2.0 tdi engine
    Sep 2011
    I think for the £ & ball ache of doing swap you'd be better off buying car with what you require in the first place.
    It's not just source engine and swap, you'll encounter mounting issues, engine ECU swap, wiring looms, etc, etc.
  7. Re: What is best 2.0 tdi engine
    46 Post(s)
    If you want a B7 chassis then buy a Seat Exeo, they're a B7 chassis but run a CR engine.
    Alot more car for your money too.
  8. Re: What is best 2.0 tdi engine
    Jul 2014
    donegal
    My pump busted so what my choice on engines will seat exeo engine fit in and not have change any thing
  9. Re: What is best 2.0 tdi engine
    46 Post(s)
    Quote Originally Posted by thebeast View Post
    Not a notion, you'll have to change ECU's etc too as its a totally different engine.
    If its the oil pump problem then give Powermax in Cookstown, in the North a ring as they fix these with 1 day turnaround.
  1. Question Golf tdi ALH engine... Engine knocking noise. Help wanted
    By Onionss74 in forum Golf MK4 - 1999 - 2004
    Last Post: 25-05-2014, 08:29 PM
  2. Replies: 0
    Last Post: 17-11-2013, 10:51 PM
  3. Replies: 4
    Last Post: 24-08-2011, 11:02 AM
  4. Question Correct engine oil for 2001 TDI Caravelle (AUF engine)
    By guidoping in forum The Commercial Range
    Last Post: 11-04-2010, 09:26 AM
  5. Replacing my 90bhp Tdi Engine with a 110bhp Tdi Engine - Is this possible?
    By gregwillclark in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-02-2009, 11:46 AM
