Thread: 06 Plate Touran - only works on 4
Results 1 to 10 of 11
  1. 06 Plate Touran - only works on 4
    Oct 2014
    Wick, Caithness
    Hello.
    I am struggling with the air blower on my Touran. It only works on 4 which is a complete pain.
    Any clues on repairing this. I read in a Passatt thread about a resistor pack needing swapped out. Does the same apply for the Touran?
    Thanks in advance.
  2. Re: 06 Plate Touran - only works on 4
    Aug 2011
    Meath
    Yes that's probably the problem, used to be called rheostat
  3. Re: 06 Plate Touran - only works on 4
    Oct 2014
    Wick, Caithness
    Thanks for the reply. Any idea where I locate the resistor pack so I can swap it out?
  4. Re: 06 Plate Touran - only works on 4
    Aug 2011
    Meath
    Quote Originally Posted by subseasniper View Post
    In no particular order, TPS, main dealer, breaker, motor factor, ebay et.al.
  5. Re: 06 Plate Touran - only works on 4
    May 2007
    17 Post(s)
    Quote Originally Posted by Doctle Odd View Post
    I think he means where is it located on the vehicle.
    On the Passat & Golf it's on the heater duct below the glovebox, under the dash. There is a little flexible trim you need to take off that's secured with a couple of thumb screws. The Touran is probably the same. There is a little locking tab on the resistor. You lift the tab & slide the resistor sideways and it will lift out of the duct.
    Jim.
  6. Re: 06 Plate Touran - only works on 4
    Oct 2014
    Wick, Caithness
    Thanks for the replies. I bought a 240c thermal fuse from maplin, snipped out the old fuse and soldered in the new fuse.
    It works!
    Word to the wise, the salesman at maplins reckoned soldering was a no-no as the heat of the soldering iron could blow the fus.
    I wrapped the fuse wires around the legs of the resistor pack then used needle nose pliers to hold the fuse wire. I then put a blob of soldet on the tip of the iron and quickly transferred it to the fuse wires. This limited the heat transfer to the fuse and it worked fine.
  7. Re: 06 Plate Touran - only works on 4
    Oct 2014
    Wick, Caithness
    Hey all, well, still having problems.
    My blower would work for a couple of weeks then then the resistor would blow, I swapped it out several times for a new resistor (not the whole pack, just the thermal resistor), it blew last week and won't work at all, even without the resistor pack it no longer works on position four.
    I am guessing that the blower unit has gone, it was making screeching noises when on four, like a bearing was wearing out or something.
    Any ideas?
  8. Re: 06 Plate Touran - only works on 4
    Dec 2010
    Worcs, UK
    Yep, new blower motor and controller are needed... motor will be drawing too much current.
  9. Re: 06 Plate Touran - only works on 4
    May 2007
    17 Post(s)
    Quote Originally Posted by itavaltalainen View Post
    Yes, and it may have blown the main supply fuse now too. That's a 40A at the center of the bottom row of fuses on the dash fusebox.
  10. Re: 06 Plate Touran - only works on 4
    Oct 2014
    Wick, Caithness
    Guys, thanks for the replies, informative and helpful.
    Cheers.
  1. Touran: blower works, no air comes out the vents. Why?
    By otheos in forum Touran - Sharan - Caravelle
    Last Post: 09-10-2017, 02:52 AM
  2. Touran heater only works on 4
    By beitou in forum Touran - Sharan - Caravelle
    Last Post: 25-02-2012, 12:54 PM
  3. Please Help touran 04 plate 2.0 pd tdi sport
    By k31tha in forum Touran - Sharan - Caravelle
    Last Post: 28-05-2011, 11:13 PM
  4. Please Help 99 Cabrio - fan only works at highest speed; A/C only works in sppeds 1-3
    By yueli831 in forum Golf MK4 - 1999 - 2004
    Last Post: 29-11-2009, 09:26 AM
  5. Resetting a 6 disc changer 07 plate Touran
    By elroy in forum Touran - Sharan - Caravelle
    Last Post: 21-09-2009, 04:41 PM
